Coolant problem....help!
Old Feb 18, 2005 | 09:22 AM
EVO_GUY's Avatar
Unhappy Coolant problem....help!
heres the problem, i recently put a 3" catback and a helix dp. i replaced the coolant in the radiator the other day. while replenishing the coolant in the radiator, i filled the radiator and the resivor tank to its capacity and then let the car run for about 5-10 min. coolant in resivor tank gets low. no problem fill it right up. took the car out the next day only drove the car for 10 min checked the coolant again and the resivor tank is half empty again. i keep having to add coolant. can anyone give me some info to whats going on? thanks
Old Feb 18, 2005 | 09:26 AM
Curt@MrLed's Avatar
Former Vendor
are you filling it to the top... your only supposed to fill it to the fill line...you have to have room for the coolant to expand and contract...read your manual..
Old Feb 18, 2005 | 11:01 AM
EVO_GUY's Avatar
yes i am only filling it to the fill line
Old Feb 18, 2005 | 12:28 PM
lancerdealer's Avatar
Air pocket?
Old Feb 18, 2005 | 12:39 PM
Curt@MrLed's Avatar
Former Vendor
well if it keeps overflowing, get a pressure test done on the cooling system.. most likely it will be a head gasket or cracked head..
Old Feb 18, 2005 | 01:02 PM
EVO_GUY's Avatar
$hit, hope nothing is wrong cause i just bought the car last month. the car only has 1500 miles.
Old Feb 18, 2005 | 01:06 PM
tokeone's Avatar
do you have signs of overflow?
i had to keep adding to mine after i drained it too.
it just took 2 or 3 times to get it done
Old Feb 18, 2005 | 01:11 PM
mifesto's Avatar
wait are you driving it for 10 minutes then waiting for the car to cool? u know the reservoir will get low when the car is hot....
Old Feb 18, 2005 | 01:14 PM
mrbkkt1's Avatar
don't forget, that when you drain your coolant, and then fill it back up, there is space in the engine as well as the hoses. i wouldn't worry too much unless you have white smoke from your exhaust or unless your oil turns milky. just keep filling a little @ a time.
Old Feb 18, 2005 | 02:47 PM
EVO_GUY's Avatar
currently there are no signs of overflow. ill drive the car for another couple of days and keep an eye out on the coolant.
Old Feb 18, 2005 | 06:43 PM
11secEVO7's Avatar
currently have the same problem...every morning i have to add a little water.
but I have noticed mine overflowing after spirited driving. and even after it cools down..it's pretty low.
Old Feb 18, 2005 | 06:56 PM
JDM_FeTiSh's Avatar
From: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
when you are changing your coolant, you should fill it to top it off, and let it run for 10 to 15 min. until you're t-stat opens. the top hose and bottom hose should be same temp.. making sure u dont have air bubbles,keep squeezing the hoses till its gone. shut it off. check your resevoir and fill it to the line if its low.
Old Feb 19, 2005 | 12:44 AM
feriosi'evotwin's Avatar
sounds like u have air in coolant system did u try bleedin' it
rayman0690
Apr 5, 2011 02:12 PM
evrblazin
Apr 14, 2010 08:44 PM
mrbkkt1
20
May 31, 2007 07:00 PM
mac_05evo
19
Jul 7, 2006 06:22 AM
EvilDylan
Oct 13, 2005 09:50 AM
