Oil coming out from exhaust manifold?? (HELP!!!)
Old Feb 26, 2005 | 01:08 AM
tlclee's Avatar
oil passage uh...I didn't know that. I am taking my car back to the dealer on tues and I will let you guys know after.
Old Feb 26, 2005 | 02:06 AM
EVO8LTW's Avatar
Originally Posted by TrinaBabe
There is an oil passage behind one of the studs for the exhaust manifold. Im sure it is leaking and thats all. Its a very common problem on DSMs. Have you removed the manifold before? I would just remove the manifold, replace the gasket, tighten the hell out of all the studs and put it all back together. Im sure its nothing terrible if your not blowing a ton of smoke out the back.
Weird. So do some of the bolts need sealant?
Old Feb 26, 2005 | 09:51 AM
TrinaBabe's Avatar
It would be good to use something I suppose but I have no idea on what would take the heat. You should be able to tighten the studs enough to ensure no oil leakage. Also, you can tighten the manifold on tighter than crap considering they are studs hold it on. Between the gasket being squished on by studs and the actual stud in the passage it should be enough. Always make sure you change the gasket when removing and re-installing.
Old Feb 26, 2005 | 07:26 PM
tlclee's Avatar
I ain't touching it....its under warranty so Mitsu should be worrying about it.
Old Feb 27, 2005 | 10:31 PM
mhutch's Avatar
This is the stupidest post that I have ever seen. Period.
This is going in my sig as the stupidest post that I have ever seen...
Old Feb 27, 2005 | 10:34 PM
mhutch's Avatar
See.
Old Jul 3, 2006 | 03:21 PM
evil mechanic's Avatar
See.
i know this is old but the guy who said he is gonna put it in his sig because it is stupid is a fawkin retard. TrinaBabe is 100% accurate in what he said.
Old Jul 3, 2006 | 04:24 PM
mayhem's Avatar
lol. classic
Old Nov 14, 2006 | 03:35 PM
C6C6CH3vo's Avatar
edited because I found an image which clearly represents what I said last year. I also want the information to be known so someone doesn't tear their car apart or loose sleep over residual oil on cast to head surface.
Originally Posted by razorlab
Exhaust manifold studs leaking? Leaking what? LOL
Leaking oil
So you are saying the threaded holes for the studs are either drilled all the way into the head where oil is or drilled through an oil passage? Top studs or bottom ones?
Yes. There is no top or bottom passages here, just the passages that lead to crankcase from head. The bolts can be seen protruding into these passages in the image below:
Old Nov 14, 2006 | 05:49 PM
the lower far right and lower far left manifold studs have oil passages behind them. they are the only 2 studs that are larger in diameter than the rest. i found this out when i swapped my stock studs for ss studs and they leaked. i took them back out and used teflon tape and never had another problem with them again.
kkeller
May 3, 2017 11:22 AM
Chokkan
23
Mar 9, 2017 11:38 PM
DanielM
Jun 30, 2016 11:25 AM
CosmotheJTAC
Sep 3, 2012 06:44 PM
Estorilblau
Lancer Troubleshooting
Mar 14, 2012 12:39 PM
