Transfer case question (and problems)
Old Feb 25, 2005 | 11:36 AM
Agent-Smith's Avatar
They seem to be - I havent heard of any transimission or tcase problems on the 05. I have heard of some problems with the rear diff, just have it inspected and make sure all the fluid levels are good and you will have no problems.
Old Feb 25, 2005 | 12:15 PM
TomG's Avatar
..the rear diff? You mean they might not have the correct amount of fluids in them?
Old Feb 25, 2005 | 01:22 PM
megatron's Avatar
i have been having transfer case whining noise problem for about a month now. should this be something the dealer should take care of? cuz i have a lot of parts on the car that i had to take off when i had to go get smogged, and id hate to have to take them all off again a second time. im thinking about just picking up a used cheap one from someone. how do you distinguish between tranny or transfer case problems? and should i get this whining noise fixed ASAP or can i hold out for awhile until i save up for a new tcase?
Old Feb 25, 2005 | 01:53 PM
If the sound happens when the car is still in neutral (decel) then it is your tcase. If it is your tcase *I* recommend replacing it as soon as possible. From what I have read and heard if the tcase truly fails all 4 wheels will lock up.
Old Feb 25, 2005 | 07:51 PM
bpclements's Avatar
03 Evo tranny's suck. Mitsu actually has TSB's out on the tranny recommending updating the syncro's. That's prolly what is causing all of the problems. With the t-case problems it's cause they come from the factory mis-aligned.
Old Feb 25, 2005 | 07:53 PM
bpclements's Avatar
Agent-Smith, I bet your problem comes from the fluid they are using. I would find out about that. My evo's got 42k miles on her now. I have the decel noise but my t-case is good so far.
Old Feb 25, 2005 | 07:58 PM
platinumspecv's Avatar
Dude how do u blow 2 tcases? seriously you must be a very aggressive driver. Also - be sure to put in redline diff oil. Put the good stuff in there. Take care of the 3rd one.
Krunal
Old Feb 25, 2005 | 11:59 PM
Krunal
Before you go spouting off at the mouth, both of the cases were defective (incorrectly shimmed from the factory). Redline fluids are known for eating the synchros in our cars so I am not to sure about the lsd fluid either. I had them in my car at one time and really did not notice that big of a difference.
Old Feb 26, 2005 | 10:47 AM
bpclements's Avatar
I'm still on the search for a good fluid. Guess I won't find that fluid untill I get a rebuild on both the tranny and t-case. Then they might work correctly and I will use the fluid they recommend.
Old Feb 26, 2005 | 03:11 PM
rt turbo's Avatar
Originally Posted by Agent-Smith
Alright so I am now on my 3rd transfer case (nice build quality mitsu!). Anyhow I got the car back yesterday and everything seems well. I let her warm up fully and merge on to the interstate - i go WOT for a very short period just to check things out, thats when the problems begin.
At anything over ~14 psi I start to get a VERY loud WHRRRRRRRRR sound (gears?) that is louder than the turbo hiss. I checked a couple of times and this does not happen unless the car is up to operating temperature.
I am thinking maybe they did not put enough fluid in the TC?
your on your 3rd trans case! dude, you can officiallyy call the car a lemon and have it fully refunded! Its under the lemon law that if you break and repair at your cost, or anyone elses cost 3 times, the manufacture must pay you for the car what you paid for it. take it back. your the first ive heard of it breaking this many times.
Old Feb 26, 2005 | 03:13 PM
rt turbo's Avatar
IM GOING TO EMPHASIZE THIS AGAIN.... LEMON LAW!
call that one place , its like the buruae (sp?) of motor safety or something, im sure someone will know it.
Old Feb 26, 2005 | 04:42 PM
Unfortunently I cant lemon it yet. My definition of 3rd.
#1 tcase that came with car
#2 first replacement tcase
#3 tcase I am on now
Old Feb 26, 2005 | 04:50 PM
rt turbo's Avatar
i was under the impression you broke 3, even though, if this one is messing up, you may be able to proceed.
Old Feb 26, 2005 | 08:49 PM
megatron's Avatar
just rev that ***** to the rev limiter and dump the clutch until it breaks. then get a new evo.
Old Feb 27, 2005 | 02:28 AM
haha wish i could wish i could... the last one already was insepected for abuse. I passed (aka it wasnt abused) and Id like to stick it to them properly if I have to.
