Transfer case question (and problems)
Old Feb 25, 2005 | 07:48 AM
Agent-Smith's Avatar
Alright so I am now on my 3rd transfer case (nice build quality mitsu!). Anyhow I got the car back yesterday and everything seems well. I let her warm up fully and merge on to the interstate - i go WOT for a very short period just to check things out, thats when the problems begin.
At anything over ~14 psi I start to get a VERY loud WHRRRRRRRRR sound (gears?) that is louder than the turbo hiss. I checked a couple of times and this does not happen unless the car is up to operating temperature.
I am thinking maybe they did not put enough fluid in the TC?
Old Feb 25, 2005 | 08:02 AM
sabastian458's Avatar
it would do that noise all the time if there wasnt any fluid, is it a mechanical whrr or like a wind noise whrr? and it only does it at wot?
Old Feb 25, 2005 | 08:04 AM
mechanical whrr. Yup it only does it at wot. Doesnt seem like the turbo though because it still spools perfectly and holds boost just fine. (ebc set at 19)
Old Feb 25, 2005 | 08:20 AM
pull your drain plug and see if it has abnormal amount of metal shavings or chunks, if it doesnt just put a different fluid in it as long as the fluid is a lsd type
Old Feb 25, 2005 | 08:32 AM
EVOla_VIRUS's Avatar
Im to a point where having a car that is down really angers me.; I have not reccomended anyone to buy this car due to mechanical build quality. Some of these issues are simply unexusable...certainly if failure occurs for the 3rd time.
Old Feb 25, 2005 | 08:51 AM
GinuwineEvo8's Avatar
3rd time? Replaced via warrenty? Lemon-Law homie ...
If not then .. I dunno .. driving style perhaps?
Old Feb 25, 2005 | 08:57 AM
EVIL_EVO_VIII's Avatar
Take a sample out of the fluid and have it analyzed. Alot of mitsu techs are known to be dumb asses and put the wrong fluids in!!
Old Feb 25, 2005 | 09:08 AM
Oh the key factor i forgot to mention. This is a brand new tcase with less than 100 miles on it. Just got it back yesterday.
Old Feb 25, 2005 | 09:12 AM
w_tomas's Avatar
Scott - Barry said that he got the same sound. He found that the fluid level was low, he topped it off and the sound went away. BTW, redline fluid rocks.
Old Feb 25, 2005 | 09:16 AM
Got any still ? I had some a while back but i beleive I got rid of it.
Old Feb 25, 2005 | 09:19 AM
GEARS's Avatar
It does sound like they are filling the transfer case with the wrong oil or the gears are being heavily loaded before they get a chance to bed-in.
Call the dealer, get a hold of the parts department and ask them to check stock on this number, 3775610. If they haven't ordered this oil before then we can assume that they haven't been adding the correct oil to the transfer case.
https://www.evolutionm.net/forums/sh...light=diaqueen
Jon@TRE
Old Feb 25, 2005 | 09:59 AM
bs's Avatar
bs
If you ask me the chances of getting 3 bad/defective transfer cases is almost none. It certainly sounds like the dealership may be doing something wrong with the lubrication.
Old Feb 25, 2005 | 10:31 AM
TomG's Avatar
Does the evo8's in general have tranny issues? This scares me a little since I am bout to fork out 30K plus on a new one....please advice!
T
Old Feb 25, 2005 | 11:22 AM
So far the tranny problems are only on the 03' and 04' models. The 05's have the new active centeral differential (this is housed in the tcase).
Old Feb 25, 2005 | 11:25 AM
TomG's Avatar
So those should be stronger, and better?
T
