(10w30) motor oil comparison
Old Mar 1, 2005 | 07:45 AM
4-BNGR's Avatar
Brand VI Flash Pour %ash %zinc
10W-30
AMSOIL 171 464 -54 <.05 ---
AMSOIL XL-7500 148 471 -54 <.05 ---
Castrol GTX 140 415 -33 .85 .12
Castrol Syntec 157 455 -54 --- .10 IN MY CAR
Chevron Supreme 150 401 -26 .96 .11
Exxon Superflo Hi Perf 135 392 -22 .70 .11
Exxon Superflo Supreme 133 400 -31 .85 .13
Havoline Formula 3 139 430 -30 1.0 ---
Kendall GT-1 139 390 -25 1.0 .16
Mobil 1 --- 430 -60 --- ---
Mobil 1 Super Syn.(NEW) 145 455 -49 --- --- **
Neo 185 470 -49
Pennzoil PLZ Turbo 140 410 -27 1.0 ---
Quaker State 156 410 -30 .90 ---
Quaker State Prem Syn 148 440 -40 --- --- **
Quaker State AE Full Syn 160 440 NEW
Red Line 150 475 -40 --- ---
Royal Purple 148 400 -49 --- --- **
Shell Fire and Ice 155 410 -35 .90 .12
Shell Super 2000 155 410 -35 1.0 .13
Shell Truck Guard 155 405 -35 1.0 .15
Spectro Golden M.G. 175 405 -40 --- ---
Unocal Super 153 428 -33 .92 .12
Valvoline All Climate 130 410 -26 1.0 .11
Valvoline Turbo 135 410 -26 .99 .13
Valvoline Race 130 410 -26 1.2 .20
Valvoline Synthetic 140 450 -40 <1.5 .12
Old Mar 1, 2005 | 07:59 AM
Ev0 1's Avatar
Can you explain what all of that means? I'm clueless when it comes to this....
Old Mar 1, 2005 | 08:00 AM
4-BNGR's Avatar
#1 Neo
1-800 - 959 - 7757
CA.
#2 Spectro Golden M.G.
1-800-243-8645
Spectro Oils of America, 993 Federal Rd. Brookfield, CT. 06804
These are my recommendations for "superior" 10w30 motor oils. Yes they cost a bit extra but the life of these oils is expponentially longer than conventional store bought oils. And the performance characteristics of these oils speaks for itself.
4-BNGR
Old Mar 1, 2005 | 08:06 AM
berkel's Avatar
hi,
Could someone comment/explain the various ratings please. Like a higher value for x is "good" and a lower value for y is "bad".
I've had good experience with NEO RHD for my GL-5 tranny fluid.
Thanks,
FB
Old Mar 1, 2005 | 08:14 AM
4-BNGR's Avatar
VI= Oil Viscosity Index (Viscosity Index is an empirical number indicating the rate of change in viscosity of an oil within a given temperature range. A low viscosity index signifies a relatively large change in viscosity with oil temperature, while a high viscosity index shows a relatively small change in viscosity with oil temperature changes, providing viscosity consistency and stability).
Flash Point= an oil's flash point is the temperature at which "a flame appears and instantaneously propagates itself over the entire surface. The oil flashes because a flammable mixture results when it is heated sufficiently, causing vapors to emerge and mix with oxygen in the air.
Pour Point= The lowest temperature (in °F or °C) at which a liquid remains pourable (meaning it still behaves as a fluid).
%ash=A high ash content will tend to form more sludge and deposits in the engine
%zinc= available research shows that more zinc does not give you more protection, it merely prolongs the protection if the rate of metal-to-metal contact is abnormally high or extended. High zinc content can lead to deposit formation on your valves, and spark plug fouling.
An amazing article on the topic of motor oil http://www.vtr.org/maintain/oil-overview.html (I suggest saving it to "favorites" in your web browser)...
4-BNGR
Old Mar 1, 2005 | 01:06 PM
4-BNGR's Avatar
For those that are interested, the NEO 10w30 motor oil is $35/gallon And it will absolutely destroy the poo out of M1, Redline, AMSoil, etc. A very worthwhile investment in my book, and the oil is specific to Turbo applications... Here's more info for the skeptics... http://www.neosyntheticoil.com/
Old Mar 1, 2005 | 04:17 PM
mr_one's Avatar
What gear oils would you use from Neo, they dont list any GL numbers on their website.
Old Mar 1, 2005 | 05:09 PM
4-BNGR's Avatar
75-90 HD http://www.neosyntheticoil.com/75w90hd.htm It's all there, just browse around http://www.neosyntheticoil.com/site.htm These products are amazing. For example the motor oil is good for 25,000 miles or 1 year (whichever comes first)
Super DOT 610 Brake Fluid
Old Mar 1, 2005 | 05:58 PM
berkel's Avatar
I used the RHD for everything in my Wife's old WRX and in the rear diff and tc in my EVO. It's GL5. I use Redline GL-4 (MT-90) in my transaxle, but someone else posted that the Neo HD (I think) is good for our transaxle, but haven't tried it.
Thanks for the info 4banger.
FB
Old Mar 1, 2005 | 06:21 PM
4-BNGR's Avatar
cheers
Old Mar 1, 2005 | 06:26 PM
badlooser's Avatar
Good stuff!
Smike
628
Oct 27, 2024 04:39 AM
TPetsch
Jan 17, 2006 01:34 PM
WarmPepsi
Oct 2, 2005 08:11 PM
PiNG
Feb 27, 2005 04:19 AM
