Boost problem
Old Mar 9, 2005 | 05:28 PM
onpol's Avatar
Boost problem
Hi to everyone.I been trying to find the problem of a friends EVO. The car has 32,000 miles -hallman mbc-turbo xs FMIC - Super afc- walbro pump and defi gauges. The car accelerates hard making 1.5 kpa and tapers to 1.4 but when it hits 5,500 RPM the boost starts to bounce back and forth from 1.2 to 1.3 very fast and do the same in all gears. I already checked for vacuums leaks and loose hoses with no luck. I believe the turbo is the problem but i want to hear your opinions. Thanks in advance for any help.
Old Mar 9, 2005 | 07:23 PM
EVO8LTW's Avatar
I actually have an issue like that if I set my boost controller to ramp up the boost too hard. I'm suspecting it's either a problem with my 1G BOV or the way I've got the BOV hooked up (I'm tee'd off the same line for my boost controller and boost gauge, which I think might delay pressure on the back side of the BOV when boost hits too hard and fast). What BOV is he using?
Old Mar 9, 2005 | 07:27 PM
MANGOOK's Avatar
Can it possibly be the car pulling timing which is causing the boost to bounce around.
Old Mar 9, 2005 | 07:34 PM
jeffm1999's Avatar
sounds to me like he is floating the BOV. I am running 21 psi and if it holds that for more than a few seconds, like on the highway passing some idiot, then I can hear my BOV sputtering (opening and closing really rapidly). I, too have my boost controller and gauge tapped into the same vacuum line, and I agree that there might be some issues there, but if you're friend has an air intake or a VTA BOV that you can hear, that might tell you if he is having the same problem that I am. not that it really affects performance, but I can't see how it can be good for the BOV.
Old Mar 9, 2005 | 07:39 PM
onpol's Avatar
The car has stock BOV and pipes.I already swaped a Greddy type-s and took a test drive and same thing happened.
Old Mar 9, 2005 | 07:42 PM
jeffm1999's Avatar
well if the BOV is good, then I dunno.... I can't think of a problem with the Turbo that would make boost bounce around like that, I would think it just wouldn't create enough boost. However, there are many people around here that are FAR more educated about these things then I am... sorry I couldn't help
Old Mar 9, 2005 | 07:45 PM
onpol's Avatar
jeff- thanks for your opinion
Old Mar 9, 2005 | 07:46 PM
EVO8LTW's Avatar
Is there anything tee'd off the BOV hose?
Old Mar 9, 2005 | 07:48 PM
MYEVOVIII's Avatar
Could be boost cut if he's getting to lean with the Safc.
Old Mar 9, 2005 | 07:55 PM
onpol's Avatar
Yes there is a vacuun line teed from the piece of vacuun line that goes to the intake manifold the BOV uses the same line after some hard vacuum lines.I'm using the line to monitor boost to my innovate LM1 wideband.I'll remove it tomorrow and see what happens
The car is running rich about 10.4 AF ratios
