Simple way to tell if your clutch is dying
Old Mar 10, 2005 | 06:01 AM
11secEVO7's Avatar
Cool Simple way to tell if your clutch is dying
probably really obvious to some but may be helpful to others......
put your car on a flat level surface depress the clutch and engage first gear.
If the car moves foward even just a little then this means your clutch is low.
Old Mar 10, 2005 | 09:34 AM
GTKage's Avatar
i dont think that s it man, my car has been doing that since day one, it doesn t happen all the time, only when the car is cold.
Old Mar 10, 2005 | 09:37 AM
ultraflip's Avatar
huh? i don't get it
Old Mar 10, 2005 | 10:06 AM
Lament's Avatar
This is bad advice.
Old Mar 10, 2005 | 10:08 AM
2literturbos's Avatar
Even easier,
put car in 5th see if it stalls when trying to go from a stop.
-James
Old Mar 10, 2005 | 10:12 AM
P0300's Avatar
I believe there is another thread on this phenomenon. The cause is not the clutch going bad, it usually is due to colder weather causing the transmission fluid to "thicken" thus grabbing the rotating parts of the transmission, causing it to roll a little bit. It will even occur in neutral once in a while.
Old Mar 10, 2005 | 10:51 AM
11secEVO7's Avatar
^^but after it rolls it would stop for itself.
and the times it happened to me...i pulled down the gearbox and found that my twin disc clutch was all messed up.
for example....at the drag track...
i went up to the line and stopped.....engaged first and red lighted because the car started moving foward even though my clutch was straight down....
floored it though and in fourth felt the slip...
Old Mar 10, 2005 | 10:52 AM
11secEVO7's Avatar
^^meant to say "clutch pedal was straight down '"
Old Mar 10, 2005 | 10:55 AM
NYREDEVO's Avatar
I hope thats not the case....my car will role foward in neutral sometimes!!!
Old Mar 10, 2005 | 12:27 PM
evo81's Avatar
your clutch is going
Old Mar 10, 2005 | 12:30 PM
hydrofoam's Avatar
the clutch also could be adjusted wrong... on my aftermarket one i can adjust the pedal .. and if its not adjusted right then when it is all the way at the floor the clutch isnt fully engaged... the most obvious way to tell that your clutch is gone is when you get on the gas the rpm's will shoot up without the car going anywhere... but i guess that is common sense
Old Mar 10, 2005 | 12:44 PM
EVOTEXAS's Avatar
Yeah how about the good old fashioned way of watching your tach and noticing the car not accelerating as fast as the RPMs should indicate? That's your slipping clutch. Best tried in 5th.
Old Mar 10, 2005 | 12:57 PM
Lament's Avatar
That is usually an indication of a bad slave cylinder. Not a clutch.
Old Mar 10, 2005 | 12:58 PM
petersa9's Avatar
This makes perfect sense. Put the car in 5th at about 2500 RPMs and floor it and wait for the slip, its very apparent when it happens. Time for a ACT clutch!
Old Mar 10, 2005 | 01:02 PM
lil'evil_evo's Avatar
What I would do is just drive someone elses evo with a newer clutch.
