EVC 5 offset setting & install qns
Old Mar 29, 2005 | 07:32 PM
SJ EVO 8's Avatar
Originally Posted by axl
SJ: Yar... the knobs adjust the vol. gain %-wise ON TOP of your stock boost. That is, if your stock boost is 1bar, if you dial in 50%, you will get 1.5bar.
Like what inline said, different car, different mods, weather conditions will all play a part. Experiment on your own... but make sure NOT to set an insane boost level and blow yr head gasket yar.
Thanks for the info everyone... I guess its time to take her out and experiment a little.
Old Apr 4, 2005 | 07:58 PM
bracer's Avatar
Can someone explain the offset a bit more. I'm thinking of getting the EVC 5 panel for my EVC EZII. This would give me the offset gain.
Old Apr 4, 2005 | 10:15 PM
rraulston's Avatar
Anyone have an extra Solenoid??? Mine lasted a year and went out. I wonder if it is worth fixin. Is the solenoid unit the same as the EVC EZII ????
Old Apr 4, 2005 | 10:19 PM
rraulston's Avatar
Can someone do me a favor???? With the car OFF, blow through the center tube and tell me if you can. I can blow through mine and i dont think you are supposed to. Then turn your key on and see if you can blow through the center. I can then as well. I took the unit apart and presureized the small hole that is the small tube. I get the over boost beep on the controll unit, but the servo never actuates the pin. Pressure or vacuum, the pin never moves. just studders. You would be really helping me out. Ime boosting to 30 PSI and it has to be the EVC unit.
SWOLN
Oct 15, 2015 11:07 AM
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
201Motorsports
10
Nov 29, 2007 10:34 AM
danalo
24
Jun 9, 2005 02:02 PM
NYEVO8
Oct 24, 2004 01:30 AM
