Questions on dead spark plugs.
Old Mar 12, 2005 | 07:41 PM
Silvercar's Avatar
Got a question can dead or dieing spark plugs cuase a Cel light??? I just had my fuel rails and injectors put in and tuned. The car has 17,000 miles on it and just started the cel. Its a mis fire code but can that b cuased by my plugs also.??? And yes it is a 03 but this is the first time its doing this. The idel is retarted to sometimes it will start right up some times it light maybe ill start maybe i wont any help please.??
Old Mar 12, 2005 | 08:37 PM
Silvercar's Avatar
um.. Hello.. BUMP!!!!!!!!!!
Old Mar 12, 2005 | 08:42 PM
nbpal4000's Avatar
i dont think it does..i changed fouled out spark plugs few times but never had cel on..until now..i think its just random po300 ...check the dealer if they got reflash available
Old Mar 12, 2005 | 09:00 PM
ebbeast2005's Avatar
ok, what boost are you running. Since you did the fuel upgrade im sure ur running higher boost. If so you might have got a over boost to make the cel which would detonate your spark plugs. Get some iradium spark plugs (pricey but worth it) and get you cel checked out and see whats going on.
Old Mar 12, 2005 | 09:01 PM
I didnt see that the code was a misfire. All evos have that prob. with the misfire. Get the iradium plugs and take the neg. off the battery for a sec. you will be set.
I wouldnt take it to the dealer ship to get te new software cause it could over write your flash then your going to cause probs.
Old Mar 12, 2005 | 09:20 PM
MalibuJack's Avatar
All evos DO NOT have that misfire issue.. However I would recommend changing your plugs, cheap enough insurance, at 17k miles, original plugs, its probably a good idea anyway, I use cheaper plugs (NGKBPR7ES) and change them every 5000 miles (Every oil change)
If you have a plug misfiring bad enough, it can trigger a CEL, however you don't say specifically what error code it is, if its a random misfire P0300 then thats a pretty common error.
Did you have ANY other codes thrown? Sometimes you'll have a stored code, but the light won't come on until you hit another code...
Anyway, before you get too concerned, change out your plugs...
Old Mar 12, 2005 | 09:21 PM
MalibuJack's Avatar
Also, if your having an intermittant start error, check the wiring on your turbo timer, make sure none of the wires have gotten damaged or anything else odd..
Old Mar 13, 2005 | 11:16 PM
Evoisdream's Avatar
plugs
Old Mar 14, 2005 | 03:26 AM
Silvercar's Avatar
I had a few codes frist there fas a misfire in 3. Then cleared it. Then misfire in 4. Then cleared . Then a random misfire. Then this weekend the Cel came on again then it cleared itself.
Thanks.
Old Mar 14, 2005 | 05:15 AM
11secEVO7's Avatar
i use denso 11's
actually just messed up my plugs yesterday. they're easy to check...if u dont want to check it yourself, any shop would be able to.
and as malibu jack said if the plug or plugs are really bad...it can trigger a CEL due to misfiring.
gui dube987
Oct 13, 2015 12:55 AM
Sunwalker12
Oct 8, 2013 06:05 AM
Alfriedesq
24
Dec 1, 2003 10:39 PM
