Question about peice i found in bellhousing while doing clutch install
Old Mar 15, 2005 | 07:39 AM
Zeus's Avatar
Hey, I'm at 39k on mine (granted, slipping now with 317wft lbs on a Mustang Dyno), and I'm anything but nice to it. I just don't inadvertently abuse it.
Old Mar 15, 2005 | 07:41 AM
SuperHatch's Avatar
Well I'm pretty good to my car, but I did one launch that did the clutch in, I just slipped it way too much, I smelt it and it never felt the same since. Live and learn!!!
Old Mar 15, 2005 | 08:32 AM
WildRice's Avatar
I hope that "O" ring holds up for you. The low pressure involved is on your side here but then oil does tend to seep where ever an opportunity exists. I would think that if seepage does occur it will soon make its way down the housing and become detectable throught the inspection hole. Even if with a leak and "Murphy's law", I don't believe that there is much of a path from the housing to the clutch. When weighing the risks, a clutch plate against the hassels of going back in, I think I'd just cross my fingers like you are doing.
Old Mar 15, 2005 | 08:43 AM
93civEJ1's Avatar
yeah we figured that with such a small weak gasket that it must be pretty low pressure. Im sure that if it does leak that i can maybe detect it on the ground. Im hoping the odds are in my favor.
So far I love the clutch though. Just gonna take some getting used to when taking off.
Old Mar 15, 2005 | 08:45 AM
93civEJ1's Avatar
I dont really think it would affect the clutch plate?
Old Mar 15, 2005 | 09:04 AM
Zeus's Avatar
...only if it gets fluid on it.
Old Mar 15, 2005 | 09:22 AM
93civEJ1's Avatar
oh yeah, but where that o-ring is located, that seems like that would be a slim chance.
Old Mar 15, 2005 | 09:25 AM
chinto's Avatar
Today I halfway got through the install of my clutch, doing the other half tommorow, but when i took the transmission out, inside the bellhousing there was a little rubber o-ring laying in it that was about as big around as my pinky. Any idea what that may have came from??? It was cut in one section, but I could not find anywhere that it would have came from.
iknow iknow i know
they had a issue with that o ring when they did my clutch install
on the front diff there is a big oring bout 3" and above that is a hole that looks like its for a bolt thats where that o ring goes
Old Mar 15, 2005 | 10:06 AM
93civEJ1's Avatar
Originally Posted by chinto
iknow iknow i know
yup thats exactly the one. The big one goes around the T-case shaft. The small one is directly above it. What kind of issue did they have with yours?
Old Mar 15, 2005 | 12:37 PM
chinto's Avatar
after putting it back to gether cuz it fell off on mine and they didnt see it fall after driveing the car for about 5 min the fluid would start leaking dripping down onto the exaust
if the car just sat and ran no issues but if you drove it around the block no issues if you took it for a few miles it would start leaking
hehe
i get a cookie?!
they kept thinkn the leak was comeing from the big one but when they went to order me a nother o ring they saw a second one was spost to be above it and there wasnt one there so they had one and got it done think they said took them about 5 trys to figure where it was comeing from
Old Mar 15, 2005 | 02:21 PM
93civEJ1's Avatar
hehe
i get a cookie?!
i have not noticed any leaks luckily.
Old Mar 16, 2005 | 08:12 AM
93civEJ1's Avatar
would anyone know the part number for the small o-ring? I may pick one up just in case, to have one on hand.
Old Mar 16, 2005 | 04:38 PM
93civEJ1's Avatar
do you guys think i would be able to see or tell if its leaking by looking on the ground after driving? i really would hate to have to pull the transfer case back off.
Old Mar 17, 2005 | 05:15 AM
93civEJ1's Avatar
bump for leak question. (oh i do not have my own personal floor jack)
Old Mar 17, 2005 | 06:21 AM
93civEJ1's Avatar
I just put that o-ring on order from the dealership just to have in case I eventually do need to slide the t-case back off. That way ill have a fresh one ready.
The pez
Mar 19, 2017 01:43 PM
nickelndime
Apr 17, 2016 11:29 AM
Randal
Dec 11, 2015 09:01 AM
03nevaevolution
Dec 11, 2015 08:41 AM
grenade
12
Feb 23, 2007 07:41 PM
