heard of direct hits spark plugs?
Old Mar 13, 2005 | 09:10 AM
Derek888's Avatar
What are your thoughts on these. On Dsport mag they tested it and gain 10 hp on the dyno with a Civic.
http://www.directhits.com/
Old Mar 13, 2005 | 05:37 PM
yesevo's Avatar
let us know if they have direct hit spark plug for our evo.
Old Mar 13, 2005 | 05:51 PM
purecoda's Avatar
sounds interesting. any engine guru's want to throw in their 2 cents?
Old Mar 13, 2005 | 05:52 PM
purecoda's Avatar
$195 bucks for the 2.0 lancer BTW (not the evo).
Old Mar 13, 2005 | 06:04 PM
timzcat's Avatar
What a bunch of BS. 500 amps of spark power. LMFAO
It would burn the tip right off the plug.
Regardless you aren't going to get to try them. Evos are coil on plug and looking at those pictures you'll never get the coil back on.
Old Mar 14, 2005 | 07:49 PM
yesevo's Avatar
what kinda ignition set up u guys recommend for stock turbo (400whp)?
Old Mar 16, 2005 | 05:04 PM
jsprat7's Avatar
bump on what he said^^^^
Old Mar 16, 2005 | 07:12 PM
Ninj0x's Avatar
From the picture, it looks like it would fit.
Old Mar 16, 2005 | 08:16 PM
erikgj's Avatar
Evos are not coil on plug. They have two coils mounted to the valve cover. They fire two cylinders together. One being a waste spark. They are group cylinders (1&3) and (2&4) together.
The instructions call for resetting the ECU which could be responsible for most of the reported power gain. The supporting tech articles are not very good either.
If I need better spark I'll go with Buschurs coil on plug conversion or the HKS DLI 2.
Old Mar 16, 2005 | 08:56 PM
timzcat's Avatar
There are only 2 plug wires. 2 of the coils sit over the plugs and have a boot on the bottom side of the coil. That was my point.
Edit: Oh and the coils are 1&4 and 2&3.
Old Mar 16, 2005 | 08:58 PM
timzcat's Avatar
I don't agree. That setup looks quite a bit longer then a standard spark plug to me. How would you adjust for that length on the 2 coils that are directly over the plugs?
Old Mar 16, 2005 | 09:00 PM
TEXSRT4's Avatar
here you go guys, for the EVO's
http://www.directhits.com/OrderOnline4.asp
Old Mar 16, 2005 | 09:02 PM
MalibuJack's Avatar
You would likely have to run the shorter plug boots for the coils from a 2.0 standard lancer to get these to fit on an Evo..
These devices are basically capacitors, so they do work... Somewhat.. the problem is your still at the limit of the quality of your current ignition system.
FWIW the Lancer and evolution and most of the 2.0 4G series engines with dual coil waste spark systems share the SAME EXACT COIL, only the boot and plug wires differ..
These are probably NOT worth the money.. if you want to run them, you might have to run that nology setup that moves the coils to a bracket and runs wires to the plugs if the 2.0 standard lancer plug boots are still too long..
Old Mar 16, 2005 | 09:11 PM
timzcat's Avatar
I don't see how these can truely be effective. Most DIS systems are already capable of 80,000 volts with a decent amperage. If you need these then I would think you need to upgrade the ignition system and not try to patch it.
I've had MSD and am all for it in the right application. This is effectively a passive CDI attempt that IMHO is just not as effective or worth it.
Old Mar 16, 2005 | 09:16 PM
xtreme571's Avatar
hmm...i wonder wat r the gains on lancer...are they better than the nologys???
AboodsEvo
Nov 22, 2010 07:34 PM
nukblazi
Mid-Atlantic Region
Aug 8, 2008 03:30 PM
Rowdy
West Region
16
Apr 26, 2004 03:24 AM
