Arp Head stud
Old Mar 18, 2005 | 10:26 AM
SuperHatch's Avatar
Here's a question.... I had ARP headstuds installed a little over 6 months/6k miles ago. Should I pull my valve cover and recheck the torque? If so, when rechecking the torque should I just put the torque wrench on to tighten, or should I loosen them all a quarter turn then retighten? Or loosen them one at a time in the proper torque sequence and retighten?
Old Mar 18, 2005 | 10:27 AM
BSREVOLUTION's Avatar
loctite and atleast 85ft/pounds.
Old Mar 18, 2005 | 10:30 AM
hotrod2448's Avatar
Be sure to put the lube on the base of the nuts and the washers as well. This will help to get a more accurate torque.
Old Mar 18, 2005 | 12:01 PM
Jorge T's Avatar
3.5 k miles with recomeded ARP procedure @ 24psi no oil seepage. I have rechecked TQ values twice since install everytime all checked out.
Old Mar 18, 2005 | 12:04 PM
Kuba23's Avatar
Pruven just put mine in and they torqued them down to 80
Old Mar 21, 2005 | 01:35 AM
Dboey's Avatar
Hi,
Do you guys install the ARP Head Studs with the ARP Conrod Bolt as well?
Old Mar 21, 2005 | 02:00 AM
Autoxevo's Avatar
Yes retorque. Just tighten in proper sequence, dont loosen.
Old Mar 24, 2005 | 10:31 AM
EVOKing8's Avatar
i installed them in my car...should i now run my and pull the valve cover and retourque them or jsut wait for a few hundred or so miles?
Old Mar 24, 2005 | 11:52 AM
TrikeDOutEvo8's Avatar
Dave...make sure your car RUNS first ;-)......then after a couple hundred miles...if you have no leaks....your fine...believe me on that..lol
Old Mar 24, 2005 | 12:02 PM
kcevo's Avatar
I torqued mine to the recommended 65/70 ft-lbs and after about 3k - 5k miles it started to leak. Replaced with HKS 1.0mm gasket and retorqued using a 3 step method 70-80-90, and it didn't leak ever again.
