SBR 2.3 GT35R Dyno results
Originally Posted by wilson1
Mark,
Can u give a description of your stroker kits, power output, and also what kind of associated equipment recommendations?
Thanks,
Wilson
Thanks,
Wilson
we also sell these assembled in the blocks already with the required clearnacing of the block needed already done, with and without cores.
Thanks
Mark
SBR
Mark,
Thanks,
Wilson
Thanks,
Wilson
Originally Posted by SlowboyMR
So any other questions about the set up or our stroker kits??
Mark
SBR
Mark
SBR
Originally Posted by Turbo13
Yes do you have to have aem ems or similar engine management to run a stroker setup. Is at all possible to use a piggyback computer like utec?? I want to go bigger and like the idea of faster spoolup, but I don't want to go HUGE if that makes sense. I would like this setup but with a more conservative tune and more streetable. I guess I want more power with as close as I can get to stock like drive. thanks allen
Mark
SBR
i will try to answer all the questions here..
Spool up is awesome. like 300 rpms different from stock.. maybe craig the owner will chime in too.. 1st gear it pulls harder than my R1. In a straight line 1st and 2nd full spin, and 3rd will spin a little and get going hard..
Yes its a AEM EMS, our FMIC kit.
Mark
Mark
but mad props to the big numbers!
Originally Posted by KevinD
just curious, what is your definition of "spool-up"? because those graphs, dispite how amazing they are, show your not reaching max torque until just under 6000rpm. that to me says your not spooled up until 3000 rpm after stock... generally spool-up means you reach max boost, where the car is making the most power.
Thanks for the props!
Mark
SBR
Originally Posted by 93civEJ1
to do a stroker motor does any machining have to be done to the block, or is it just the Crank and pistons that make the difference???
Mark
SBR
Originally Posted by Kwman
This is amazing, awesome work guys. Thanks for the quick answers.
Originally Posted by cruizinmax
Your car doesn't make max power at the exact instant that you hit peak boost. If that were true supercharged guys would make max power at 1000 rpm.
Mark
SBR
here is an 03 cobra with nothing but exhaust. you can see the instant they started the dyno run he was at max torque +-25ftlb. this is by no means the best dyno i have seen, but i did a quick search to find it for you. notice that there is no huge rise in torque as the supercharger builds up boost, primarily because he doesn't have to wait for the boost.
http://www.cardomain.com/member_page...73_30_full.jpg
in the GT35R stroker plot with 500+hp, hes not making peak torque or HP until 5-6k rpm. and if your making max boost at 3k rpm, there is something severly wrong with your car or the dyno. the HP curves are always rising because it is a function of RPM and torque. the torque curve is rising because you are still building boost and increasing the torque... although the power is insane, i would want to see a plot of your boost level on that same plot to believe you make peak boost by 3k rpm. i would bet your not making peak boost until 5000 rpm which is no where near stock (but then again your making more then 2x as much power as stock
which i'm sure is fun as hell regardless of the turbo lag)so just to make this clear before it starts a flame war, i am impressed with these numbers. i am not knocking on any products, i am just trying to clarify that either this car is indeed making max boost at 3000-3500 rpm, or if the larger turbo even with the stroker setup, is just to large to make "useable" power (and by useable i mean having a power band greater then 2krpm). and also for reference, i am sort of looking into different turbos and the GT35R was one i liked, but grated it makes sick power, i'm thinking the turbo lag is just to great for anything i will be using it for.
any insight is welcomed in my confusion over the dyno charts, and the more detail the better (retarded timing is the one thing i could think of to explain such "low" torque levels at 3-4krpm when "max" boost was achieved) and once again, congratulations of the impressive numbers
