changing stock 02 w/ Wideband 02 sensor?
Old Mar 26, 2005 | 09:51 PM
plokivos's Avatar
what happens?
I know the stock is sending narrow band o2 readouts to the ECU, but if you change the sensor that reads wideband, does that effect how the ecu runs?
if so, better or worst?
Trying to decide between plx and aem uego wideband and this question poped in my head.
I'm sure nothing happens, but curious to see what you think. maybe it'll run better or you could actually tap a $50 a/f gauge and it'll read wideband... lol just maybe.
Old Mar 27, 2005 | 08:27 AM
SwiftEVO's Avatar
Your ses light will come on. I dont know about you but that bugs me, Even if I know why.
I was just thinking about putting a bung in the down pipe and running the wideband off of it and leave the stock o2 in there. Would that work?
--Josh
Old Mar 27, 2005 | 10:40 AM
marksae's Avatar
Although the AEM UEGO wideband has a 0-1V output, that signal does not simulate a narrowband o2 sensor output. A narrowband's signal oscillates when your ECU is running closed loop. The AEM's signal will not. I'm not sure about the PLX.
The best thing you should do it just have an extra bung welded in your downpipe and keep the two systems independent of each other. The stock o2 sensor has a heater circuit that the ECU controls as well.
Old Mar 27, 2005 | 11:36 AM
Jamie@WORKS's Avatar
The Innovate products WORKS carries have the capability of converting the wideband to mimic a narrowband signal that keeps the ECU happy.
Old Mar 27, 2005 | 11:56 AM
marksae's Avatar
BTW, the life of the sensor will vary depending on placement. Since a wideband has its' own heater, you don't need to place it that close to the engine. If I were using the front o2 sensor location, I'd just keep it in there long enough to get my tuning done and then take it out.
Old Mar 27, 2005 | 12:17 PM
si_eater's Avatar
i have a question what if i have a cell fix(buschur racing) in the stock second o2 sensor and just remove the sensor and screw in the wideband, would i still get accurate enough readings to tune with and would the cel stay off?
thanks
oh yeah i am running cat delete , and the wideband is a utec tuner wideband
Old Mar 27, 2005 | 12:20 PM
marksae's Avatar
If you're running catless, then having the wideband in the stock rear o2 sensor location will be fine for accurate readings. Does the UTEC tuner wideband simulate a narrowband signal?
Old Mar 27, 2005 | 12:22 PM
si_eater's Avatar
^^^^ thats a good question i dont know i just got it and im studying up on it before i install it is the tuner plus the expensive one it may. i really have no clue
Old Mar 27, 2005 | 12:42 PM
si_eater's Avatar
Bump
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
89turbosupra
Feb 12, 2016 06:03 PM
j_barcarse
Jan 11, 2012 07:53 AM
Rob_GPT
Sep 23, 2008 06:38 AM
Wicked E
11
Apr 28, 2008 03:48 PM
