Best clutch for a 10 sec daily driver?
ok this is what happened on the said day.
Got the car home....reversed it and parked it in the garage. Then it cuts off.
Looking for the clutch pedal only to find that it's stuck on the floor. the reverse gear wont come out. Eventually got it out.
Then try the gears with the car off...they move into place as they should..Start the car....the pedal comes up...feeling normal.....but the gears refuse to go in....not even how hard you push it. they aint goin in...
what could this be?
what could this be?
what could this be?
what could this be?
Good Luck,
Originally Posted by MattGold
Since it is a pull-type clutch in your car, if the clutch is on the floor, that sounds like a problem with the hydraulics. Rebleed the system, then replace the cylinders, slave then master to try and pinpoint the issue.
Good Luck,
Good Luck,
Jon@TRE
evodude32
259
Aug 26, 2015 09:22 PM
mrfred
Jun 15, 2015 06:26 AM
Arista Performance
Evo 'For Sale' Engine Internals and Drivetrain
93
Jun 29, 2014 09:04 AM
Arista Performance
EvoX 'For Sale' Engine Internals and Drivetrain
94
Jun 29, 2014 08:58 AM
