Traction Action !
Old Mar 29, 2005 | 03:59 AM
DynoFlash's Avatar
Traction Action !
Last year, I had a lot of trouble launching my Evo - having spun the heck out of my drag radials all the way through 1st and 2nd gear. And sometimes breaking the rear half shafts. I turned to the help of master AEM tuner Sean Ivey at www.iveytune.com to inquire of his suggestions. My plan was to set up my AEM with vehicle speed controlled boost and have the boost gradually build off the line so the tires would not break loose and go easy on the half shafts. Sean suggested I try and harness the power that I had not de-tune it by lowering the boost.
I set out to find some way to get the full 34 psi of boost power dowmn to the ground
Hence my traction action program over the winter which is taking shape
First I have the amazing Stage V half shafts from the Drivehsaft Shop which are rated to 1,000 whp (should hold me! HA )
Second I have added the Quaife front diff which should give me a huige advantage on the lanching power delivery. Resally a great product so its time to test it !
Frankly I am amazed with th amazing quality o te Quaife unit 0 worth waiting for for sure!
Old Mar 29, 2005 | 04:02 AM
DynoFlash's Avatar
Love my new quaife !
Finally - to tie it all together these new bushings from AMS which go in th rear trailing arms are supposed to help reduce wheel hop.
Old Mar 29, 2005 | 04:31 AM
dcorn's Avatar
Wow looks good, wish I could see your car run. Let us know if you ever get to Maryland International Raceway and I'll come check it out.
Old Mar 29, 2005 | 05:05 AM
sleet's Avatar
Sweet stuff
Old Mar 29, 2005 | 05:13 AM
eve-slow's Avatar
I just purchased the rear trailing arm bushings as well, great t-case insurance for $75.
Old Mar 29, 2005 | 06:24 AM
11secEVO7's Avatar
^ where do I get them?
thanks...
great setup Al!!!
Old Mar 29, 2005 | 07:14 AM
lil'evil_evo's Avatar
thanks...
great setup Al!!!
Great stuff Al. I'm guessing at AMS.
Old Mar 29, 2005 | 01:47 PM
DynoFlash's Avatar
Yes AMS
Old Mar 29, 2005 | 02:03 PM
plokivos's Avatar
ah, only if i had a shop.
i'll be pimping parts in the name of marketing and R & D.
Old Mar 29, 2005 | 04:49 PM
WHTEVO's Avatar
nice parts. how much were the rear half shafts?
Old Mar 29, 2005 | 04:54 PM
bolsen's Avatar
I saw the bushings on their wite a few weeks ago, but I took it as a gimmick since I hadn't heard of people having big issues with wheel hop.
Perhaps I should take another look...
Old Mar 29, 2005 | 04:57 PM
BSREVOLUTION's Avatar
wheel hop is what kills tc's.
Old Mar 29, 2005 | 05:30 PM
DynoFlash's Avatar
When you get to a certain power threshold things get out of control. The wheel hop gets nuts. I dount this will stop it 100% but I am willing to try. I have a few other tricks going on but wont give away all my secrets.
Old Mar 29, 2005 | 05:49 PM
dolemite45's Avatar
I've seen some solid pillow bushing replacements posted somewhere on this forum-- how would you compare something like that with these poly bushings? Overkill? Test those too and report back?
Old Mar 29, 2005 | 05:59 PM
bolsen's Avatar
If all goes well, I may be able to help you out. I'll drop you an IM once things fall into place.
