how does a MAF sense boost?
hi guys i realize our cars use a MAF sensor (Karman vortex) for load reference but i see thats its mounted on the inllet of the turbo.. how does the ecu know its into Boost when the MAF is before the turbo???? doesnt there have to be MAP sensor somewhere?
thanks
thanks
it "sees" how much air passes through... and makes the appropriate calculations for fuel. it doens't matter what boost you're at... it matters how much air goes into the engine... on a hot day you could be at 20psi but you'll not be seeing half the air as on a cold day at 17 psi... (that was just an analogy not real calculations).
Here is a brief description of how a MAF sensor works....
MAF Sensors
Mass Air Flow (MAF) Sensor is used by the engine control unit (ECU) to determine
the weight of the air going into the engine. To do this, Subaru uses a cylinder
shaped sensor mounted securely to the stock air cleaner box behind the
passenger side headlight assembly. Inside the sensor there is a special wire or
film which is kept heated to a certain temperature. As air passes through the
sensor, this wire or film is cooled and the sensor determines how much electricity
is required to keep the wire up to temperature. This enables the sensor to d
determinehow much air (in weight) is passing through the sensor at any given
moment. This signal is then sent to the ECU which it compares to a
preprogrammed map to deliver fuel and ignition spark, taking into account other
engine inputs such as engine RPM and temperature
MAF Sensors
thanks
thanks
The honeycolms kinda look like this 2g's (but we only have one main chamber);
http://www.roadraceengineering.com/e...wbackedout.jpg
why it alters maf signal when u put open air filter? not on stock air box with lid open?
let me rephrase that: Every Turbo MAF car must have a MAP to read boost! ???
thanks!
thanks!
Boost that we talk about in turbo land is really just a pressure difference that exists between the outlet of the compressor and the intake of the motor versus ambiet air pressure.
Think of it like a baloon ... if you take a volume of air in the baloon, and the baloon is say like 3psi above ambiet, the baloon is a certain size.
You take and squeeze the baloon and the psi inside the baloon goes up to say 5psi. But the same amount of air molecules are in the baloon.
The same thing happens in our EVOs. X-volume of air goes through the MAF and gets registered as X-volume of air. When it gets compressed, the computer really doesn't care other than the MAF just saw X-volume of air and it will mix the appropriate fuel with it.
Of course the bigger the MAF signal, the more volume of air the EVO is sucking down, which really means that you're producing more boost.
Hope that helps,
jcnel.
Hope that helps,
jcnel.
