ACT pressureplate.... and RMR clutch.... ? ?
Old Apr 3, 2005 | 08:49 PM
BeefyEvo's Avatar
Exclamation ACT pressureplate.... and RMR clutch.... PLEASE HELP ME NEED TO ORDER SOON. !!! ? ?
well basicly i want a 6puck sprung disk heres the one i like http://www.i-m-racing.com/rmrsp6dievov.html
i wanna spend around 600 bucks for everything i need to replace the stock clutch
Pressure plate.
Bearing.
disc.
ill get flywheel resurfaced if needed
looked at the ACT 2100 but i cant find any 6puck sprung discs like the RMR. so wanting to know if an ACT pressure plate will work with this disc........
or if there is an RMR pressure plate. i cant find one.
hit me with some links if ya can thanks.
Old Apr 3, 2005 | 08:58 PM
BeefyEvo's Avatar
bump =)
Old Apr 3, 2005 | 09:40 PM
j8's Avatar
j8
ACT has a 6 puck set-up for the EVO. Here is the link.
http://www.advancedclutch.com/Produc...&idproduct=914
Old Apr 3, 2005 | 09:51 PM
BeefyEvo's Avatar
i know they do but it is not a sprung disc. thats hardon other drivetrain items.
Old Apr 3, 2005 | 09:57 PM
j8's Avatar
j8
Sorry man I should read a little more before posting. Why are you not going with the ACT street disk? I payed $499 for mine. I have over 300WHP and have 13,000 miles on it with no problems. Holds great at the track and also does not kill you in traffic.
Old Apr 3, 2005 | 10:01 PM
BeefyEvo's Avatar
can you post me a link of it ?
Old Apr 3, 2005 | 10:06 PM
j8's Avatar
j8
Here you go. It is not that expensive from the vendors.
http://www.advancedclutch.com/Produc...&idproduct=915
Old Apr 3, 2005 | 10:44 PM
BeefyEvo's Avatar
Thanks..... I Just Got It From Lancershop =)
Old Apr 3, 2005 | 11:10 PM
ACTman's Avatar
The spring center disc that you were looking at is a Clutchnet disc. You can buy it direct from them if you want. The springs are not going to save your drivetrain though. They will help to make the splines on the disc last longer and the gear noise to be lessened. Our solid center puck disc is going to wear the splines of the disc faster but it's meant for racing really and the saved weight makes it shift slightly quicker. There is always some give and take in a design. Unless you making some high HP or you are racing, I would stick to the street disc IMO.
Old Apr 4, 2005 | 04:59 AM
EVOTEXAS's Avatar
What if you only put 10K a year on the Evo and want something that shifts faster and holds 400 ft lbs (not rated at 400 - HOLDS 400)?
Old Apr 4, 2005 | 08:53 AM
ACTman's Avatar
With a 10% allowance for wear, heat, and margin of safety, our street setup will hold an honest 450 ftlbs or torque (497 is the rating at peak pressure, etc). Whether it will shift fast enough or take the amount of heat and abuse you want to give it is matter of personal opinion. The ceramic puck type disc is going to sacrifice some comfort as far as engagement goes, and it will be overkill on the torque capacity. I mean Turbotrix is running that setup (off the shelf ACT parts) and runs 9.7s. I am sure he is making at least close to 600 ft lbs of torque.
On the other hand, I can go out there and fry any clutch including the $3-4000 ones in less than a couple minutes if I wanted to. Keep in mind that I make a better engineer than salesman. You are not going to find me telling people, "Our clutch is perfect. Shut up and buy it." IMO, there is no such thing as a perfect clutch for everyone. There is always a tradeoff even if the other manufacturers don't always admit it.
