I think I have the lowest cammed evo ever!?!?
here is my thread i started about low comp..i need to do a leak down test soon.. with poll
https://www.evolutionm.net/forums/sh...d.php?t=127709
Originally Posted by electricevo
Whats that about? I was just tryin to help. Unlike you who said nothing
Bad information is worse than no information.
Check your boost gauge for accuracy. I have a Defi that reads 3 psi high. Also the engine compression can vary due to the temp of the engine or the gauge. The key is to have a consistant number. If it is 150 all across then you are fine.
Find out your A/F Ratio!! Check your compression again (make sure the car is cold otherwise it could vary result wise) only this time do it once with oil and once dry then post the compression!! Also who installed your boost gauge/what kind is it, I've heard of many people installing gauges and getting false readouts b/c the gauge is only as good as the install....lastly, as many already said check for leaks!!
Who's boost gauge is the tuner referencing? Boost is where power is going to be had or lost. Are you sure your running what you think?
I would look into your knock sensor output or just verify your ignition map values... you'll suffer a large loss in power with something wrong in this area.
Then verify your a/f's.....
If a similar car with different mods are run on the same dyno, what does it matter? your using the same measuring device? His car is still making less power than another vehicle with less mods, if I read the original post right....
Originally Posted by mifesto
as stated the mustang dyno reads considerably lower
Are you still running the stock diverter valve? I just did a leak test on my car, and my stock diverter valve was leaking significantly at anything over 14 or 15 psi. That may be a place to look. I'll be replacing mine quite soon.
-Paul
-Paul
I have the bigger injectors because my idc was 99.9% with a 4th gear pull. Plus I plan on changing turbos.
It reads exactly 150 on each piston. I did the test with the car warm. Never heard of doing it while the car is cold.
My boost gauge is an autometer and I put it in myself. I know I did it right. I dont know if it is accurate though.
He was readng it off of my boost gauge. He said when he would try to add timing it would knock.
Im running a 1g crushed dv. It should be able to hold the boost.
Thanks for all the help guys. Im going to do a leak down test like lots of yall suggested. Because I am just assumning I dont have a leak because my boost hit and stays steady. No spiking or tapering down.
I will let yall know when I find something out.
--Josh
--Josh
--Josh
--Josh
