I think I have the lowest cammed evo ever!?!?
Old Apr 6, 2005 | 07:07 PM
SwiftEVO's Avatar
Question I think I have the lowest cammed evo ever!?!?
OK I dont get it. I went and got my car tuned and it just plain sucks. The tune is nice just the numbers suck. I cant figure out what is holding me back. Maybe you can help.
Ok I have:
3in TBE with cat delete
Injen Intake with upper ic piping
HKS 272 cams in and ex
Walbro 255 fp
Fic 650cc Injectors
Hallman MBC 22psi
UTEC
NGK BR8ES gapped .026
I put down 307hp and 294tq!!!! WHAT!?!?!?!
Mark from tt tuned it. He thought it was low too. Other guys there put down 340+ with similar or less mods.
There was one guy there with just a tbe, mbc, and intake and put down like 304/302.
I checked compression and each cylinder was exactly 150.
No boost leaks or anything.
Im just baffled.
--Josh
Old Apr 6, 2005 | 07:12 PM
electricevo's Avatar
I;m not sure about that spark plug gap, shouldnt it be around .044 gapped?
Old Apr 6, 2005 | 07:16 PM
bolsen's Avatar
What octane?
Old Apr 6, 2005 | 07:17 PM
j8's Avatar
j8
Where did you have it dyno'ed at?
Old Apr 6, 2005 | 07:19 PM
WHTEVO's Avatar
OH NO.
Old Apr 6, 2005 | 07:21 PM
EVOONYOASS's Avatar
What were the A/F's and can you post a dyno graph? No leaks huh. Are you sure? So you pressurized the system and it held? Did you dyno your car stock or with less mods to see what your base was?
Old Apr 6, 2005 | 07:30 PM
DSMotorsport's Avatar
Ok I have:
Walbro 255 fp
Fic 650cc Injectors
Hallman MBC 22psi
UTEC
Im just baffled.
--Josh
150psi is pretty low for an evo motor! recheck that compression if that was not a typo. Im hunting down a "low power" situation myself and just did compression test and my 03 evo made 175 to 180 psi
Old Apr 6, 2005 | 07:31 PM
BSREVOLUTION's Avatar
there are a few of us with utecs with low numbers. you should the utec switched to map 0 and have TT flash/custom tune your car and see what the difference is. justin
Old Apr 6, 2005 | 08:17 PM
SwiftEVO's Avatar
These arent iridium plugs so the gap should be .026 I believe.
I was running 93 octane.
The dyno was at FIS in McKinney TX. They have a mustang dyno. Mark from tt did the tune.
I dont know the exact a/f but here is a pic of the dyno sheet:
I dynoed at 280 without cams, utec, injectors, or tune. Most people with just a tune, tbe and mbc are making 300 or more.
No I didnt do a pressure test but My boost gauge shows 21-22psi with no taper what so ever. And no spikeing either.
I thought each piston just needed to be within 10% of each other. Is that really low? I need to do some checking then.
I dont have the money to do a flash after the chunk of change this custom tune cost me.
Thanks for the help guys.
--Josh
Old Apr 6, 2005 | 08:46 PM
PVD04's Avatar
I don't think your compression is too low. With a longer duration cam you will have a slightly lower compression reading than with a stock cam. As far as I've seen, 150 psi is within the normal range for a cammed evo.
Old Apr 6, 2005 | 11:11 PM
GTKage's Avatar
well it s a mustang dyno, they do read kinda low compare to the dynojet, without a base line from your stock state u ll never know the improvement
and waht s up with those injectors? i d like to see your air fuel ratio
and get a compression test again 150 seems a bit low, i beleive 170-190 is the norm on evo's.
Old Apr 7, 2005 | 06:40 AM
SwiftEVO's Avatar
I know mustangs read lower but that doesnt explain why guys on the same dyno, same day, same mods, were making 40 more hp than me.
Old Apr 7, 2005 | 08:47 AM
GTKage's Avatar
all right then.
so what s your air fuel ratio? i really dont think u need those big injectors with your set up, the fuel pump is enough. and recheck your compresion .
Old Apr 7, 2005 | 09:02 AM
nebolic's Avatar
why is that low? If I dyno my car I dont expect to hit more than 280WHP. I have turbo back, blitz induction, aftermarket bov, cams and P2. I'd be hella happy to hit 300WHP.
Nebo
Old Apr 7, 2005 | 09:07 AM
OH NO.
Whats that about? I was just tryin to help. Unlike you who said nothing
