HKS cam shafts
Old Apr 6, 2005 | 08:29 PM
WoODStOcK's Avatar
HKS cam shafts
i recently read into the HKS cam shafts and hear that they give good mid-high end power and even low end. what camshafts would be best for a stock car? 264/264, 264/272, 272/272? i dont plan on modding my car that much because its probably going to see the track maybe once a year, i just need the extra power incase the stis in my area try to show me whats up. the only other mods i plan on getting are turbo back exhaust and apexi power intake with aluminum air box or the arc air box. btw, do i really need a flash/ecu if i get the cam shafts? i want to keep as little mods in my car and have it simple so the dealership doesnt get mad at me. what other mods should i get that wont void my warranty?
Old Apr 6, 2005 | 08:34 PM
timzcat's Avatar
264/264 if those are going to be your mods. You definitely want to get a flash to actually get the potential out of the mods.
bluebanana23's Avatar
all the mods you plan to add will void your warrenty esp. the cams. If you want to keep your warranty then do a custom flash plus a k&N drop in. If I were getting cams I would get the 272's or even mix them. Do a search and you will find tons of info.
Old Apr 6, 2005 | 08:37 PM
Wicked's Avatar
i'd go with the 264/272 combo if you want a mild street car, good idle and good power. unfortunately basically any mod "can" void your warranty so kiss it goodbye...
Old Apr 6, 2005 | 08:44 PM
taumax's Avatar
Huh? your message didn't make sense.
You just said his planned mods would void his warranty. How would adding more mods keep his warranty valid?
Old Apr 6, 2005 | 08:45 PM
WoODStOcK's Avatar
im considering the 264/272 combo. what kind of ecu/flash are good? i was considering dynoflash but i heard they are bad and was told to go with ecutek. what others are there?
Old Apr 6, 2005 | 08:46 PM
taumax's Avatar
I agree. You fueling and ignition MAPs are calibrated with the stock cams. Changing cams will increase your VE, but your calibrations will not be optimal to take advantage of your VE gain.
Old Apr 6, 2005 | 08:47 PM
EVO8HKS's Avatar
get 272's and a flash to unleash all power
Old Apr 6, 2005 | 08:57 PM
qbbraveheart's Avatar
I myself am getting 272/272's
Old Apr 6, 2005 | 09:00 PM
Mercenary3's Avatar
From here on out, I am going to refuse to say "void warranty"....becasue the presence mods alone cannot void a warrany no matter what mitsu says. Eash case must be looked at individually.
That being said...I doubt mitsu will cover powertrain problems if you have cams. In fact, im almost positive they wont. And yes you need a reflash or piggyback.
He was planning on adding the turboback, intake, and cams
EvoDan2004
28
Jan 11, 2006 07:13 PM
-EV1L 8-
123
Nov 23, 2005 10:32 PM
TalonRcR
34
Aug 8, 2005 01:03 PM
fuzzychi
Jul 9, 2005 01:21 AM
Vivid Racing
30
Apr 21, 2005 11:28 PM
