Flash for 04 RS
Old Apr 8, 2005 | 08:26 AM
spyderx's Avatar
Flash for 04 RS
Anyone out there with 04 RS had custom flash like me?
Wondering if 04RS ECU is same as other 04 ECU from GSR.
After 272 cams and flash w/ supporting modds (intake, tbe, bov...) got about 300 whp on dynojet. Also, I do use hiflow cat instead of testpipe.
I am not sure if this output should be specific to 04 RS. I saw a 03 GSR with similar setup netting 325whp. he too had hiflow cat.
only difference was mine is magnaflow vs his catco cat...
anyone w/ insight to this???
Old Apr 8, 2005 | 08:43 AM
EVOTEXAS's Avatar
Who flashed your car? That is weak. You should have another 30 HP easily on a Dynojet.
Old Apr 11, 2005 | 01:50 PM
Jamie@WORKS's Avatar
There's no differentiation between 04 RS and any other 04 ECU when looking up part numbers.
Old Apr 11, 2005 | 01:52 PM
tke_413's Avatar
I'm almost possitive the ECU's are the exact same. Sucks your numbers are so low. My 04 RS numbers are in my sig with the mods listed.
Old Apr 11, 2005 | 01:55 PM
spyderx's Avatar
dude,
we both have similar setup, you probably are running catless though.
But still 340+ on Mustand dyno??? are you sure its not dynojet?
Old Apr 11, 2005 | 03:04 PM
EVOTEXAS's Avatar
Originally Posted by spyderx
dude,
Nope we all dyno on Mustang's here. I put down 352 on it. It's the GSC cams tke 413 and I run. They are very good!
b4c346
Aug 21, 2014 08:09 PM
Dr.Sound
23
Nov 5, 2008 09:45 AM
SinCityEvo
Oct 8, 2004 09:28 AM
[Cyanide]
Jun 1, 2004 06:52 AM
stonemonkey
Apr 12, 2004 12:01 PM
