boost spike help
boost spike help
i did a search... but when the results came back at 542 for "boost spike"... i got really lazy...
anyways... here goes...
i've gotta buddy with a pretty much stock evo... intake and turbo back exhaust... we installed her new autometer gauges in... and now... her car just doesn't seem right...
she spikes to about 1.7-1.8 bar... and depending on the speed... she'll slowly creep back down to 1.3-1.5... when the car hasn't warmed up... she'll boost to 1.2 and it'll hold with no problems...
her EGT's stay around 7 or so for regular spirited driving... yet creep up to 850++ (almost hitting 900)... when the EGT's are that high... she's boosting around 1.5-1.6 consistently...
mind you her car is relatively stock... ONLY an intake, downpipe, test pipe, and catback... no tuning or anything else...
can anyone lend any insight on to what the feezy is going on?
where did u tap the boost guage probably tyaped into the line that regulates the fuel presure and why ur seeing boost fluxuations. try moveing ur tap to the next line to the right
Whats up again =D Funny how I also seem to get to your posts..
Anyhow - anytime you add a turboback exhaust WITHOUT a MBC/EBC you will go up a few psi because of reduced backpressure.
Add that with the fuel regulator tap for the boost gauge and it might seem awkward.
If I were your homegirl I'd fork up a few bucks for a MBC (Dejon Tool/Hallman/TurboXS - whatever floats her boat) to help you turn it down a few psi.
Hope that helps!
Hope that helps!
here is a link make sure its taped right or a pic at least because i was havein simmular issues till i changed where i taped
https://www.evolutionm.net/forums/sh...8&postcount=25
just to be on the safe sides. normaly a/f steadies out after the engin warms up more so possably why u see the fluxuations till then
just for kicks n giggles
also check vacume lines possably one got split or a hole / crack in it from being pulled on and off
bringing this back from the dead...
have the dejon tool in their.... had it adjusted by one of my friends... but do to some unforseen circumstances.. the boost controller had been tinkered with and i need to set it again...
to LOWER the boost on the boost controller... is it turned counter clockwise or clockwise?
thanks for the help once again everyone
Chris d00d - Just call RRE - tell them you bought your Dejon Tool Boost controller from them and that you lost the directions and dont know weather or not <----- or -----> turns the boost up or down .. kekeke good luck ...
POST *****! LOL
POST *****! LOL
