Any Pulley Updates?
Old Apr 13, 2005 | 12:03 PM
Soon2BEVO's Avatar
Originally Posted by Evolution23
I'm happy w/ my Perrin pulley. You really notice the decrease in spool time once installed. I can't say that I notice 10-15 HP, but I'm still happy with it. No problems so far (knock on wood).
Im going to put mine on tonight. Ill post results. My butt dyno is pretty accurate. I drive the car 500 miles a week and I get on it a lot
Old Apr 13, 2005 | 12:05 PM
blackevoVII's Avatar
You're not going to see problems in a few months. It just adds more wear if you didnt have them over x amoutn of time. What that really means? Who knows. 5 thousand less miles? 8? 12?
Old Apr 13, 2005 | 12:10 PM
SuperHatch's Avatar
8 months, 12k miles, no problems
Old Apr 13, 2005 | 12:17 PM
marksae's Avatar
The best people to talk to about this is probably someone who builds motors.
Old Apr 13, 2005 | 12:43 PM
Soon2BEVO's Avatar
I did not mean I was going to post problems tonight, I was going to post if I felt any gains worth mentioning. If I dont... its coming off!
Old Apr 13, 2005 | 01:55 PM
MyGlue's Avatar
I went through a lot of pulley talk on bimmer forums a little while back. I read up on them and i ended up putting one on my e36 M3. The damage you can sustain is from harmonic amplification of the imbalance of the drive shaft. The thing is is, that this happens at a very narrow (maybe even a single RPM) part of the revband. So for that type of damage you have to be at that rpm for a good long while. If anyone has seen a physics teacher shatter a wine glass by finding the frequency, it takes a bit of time for the harmonic amplification to get to the point where it can break the glass. However, there is a good deal of wobbling the glass will go through. It seems however, that simply by replacing the crank pulley doesnt cause enough damage to break anything. Most of the bimmer guys' experience was with snapping drive shafts. However, the crank pulley was used in conjuncture with lightened flywheels as well. It was determined that FOR SURE that crank pulley's were NOT to be used with lightened flywheels. (however, some unorthodox released a LFW that was supposed to work with a lightened crank pulley) There were still doubters that didnt want to put on a potentially dangerous part (with good reason, cars are expensive investments)
For what it's worth, I had my crank pulley on my M3 and felt VAST differences. Best add-on that i put on my car. Dont be fooled by the numbers, the driving feel and response changed dramatically. The car jsut felt like it really wanted to run after the pulley.
Anyway, its all gonna come down to whether or not you want to take the risk with this part. I just though i'd pass on some info that i got along my way. I personally put it on because in my opinion, the risk was low because the engine would go up and down in revs so it wouldnt stay long enough in the harmonic amplification range to do any real damage. Again, no one can tell you for sure whether or not you should be able to do something or not. Every car is different and its best that you learn for yourself.
All in all, its all about how enjoying your car. And ofcourse, to each his/her own.
Old Apr 13, 2005 | 02:30 PM
bdking57's Avatar
ahh.. this is the best opinion yet! Truely, no one else has brought up the fact that only at a certain pitch would the pulley cause a problem untill now.
Old Apr 13, 2005 | 03:09 PM
Kaane's Avatar
BMW motors are a bit different, it takes much more to damage a 4 cylinder crank shaft, then a 6 cylinder one.
Old Apr 13, 2005 | 03:24 PM
Soon2BEVO's Avatar
OK NM on the install. Perrin make some shotty **** as far as I can see. The pulley was running up against the timing cover because of the design. Also, it has no timing mark. **** it, Ill keep stock one on.
Old Apr 13, 2005 | 03:37 PM
trinydex's Avatar
wow really? i thot they would have at least addressed the timing mark... but shewt... if it's rubbing that's all bad... so many different manufacturers of these things tho... unorthodox, authority and perrin... i think they're all on the cheap scale tho... cept maybe unorthodox...
Old Apr 13, 2005 | 03:38 PM
AMSTuning.com's Avatar
More than a year on the car - not a problem. Same with other customers.
Old Apr 13, 2005 | 03:43 PM
bdking57's Avatar
How many pulley sets have you installed in on customers cars? Were they full sets or just crank pulleys?
Old Apr 13, 2005 | 03:52 PM
unowned's Avatar
Will someone just please Balance Check the Crank Pulley for vibrations this will solve most skeptism
Old Apr 13, 2005 | 05:08 PM
SuperHatch's Avatar
My UR pulley has timing marks and doesn't hit the timing cover....
Old Apr 13, 2005 | 06:31 PM
Soon2BEVO's Avatar
It was Andrew's idea to get the Perrin
