installing Greddy S BOV
before u install, take the allen key bolts off the top, open it up, take the inner small spring out and leave the bigger spring in, close it up tight. then just install it and dump the mouth back into intake (ur hearing this from a guy who ran 4 bov's vta including the TYpe S and am running vta now). Then once installed, test it out and adjust the adjustment screw as needed. start from 2 1/2 turns from contact. thats it.
first try it without doing any mods to it
I finally modified my BOV, and let me tell ya. I'm not going back to double spring. For me it seems to be holding boost very well/ no leak back what soever, but i'm only hitting 1.2 1/2 max. If you care about the sound, it's beautiful. More audible then before, if you follow the instruction I gave you. I used to have stalling problems, but not anymore. It's almost like the stock BOV, but better in a way.
Goodluck!!
Goodluck!!
its basically a FACT that the type S single spring modded will run better, but yea u can try it without modded
I finally had to give mine about 6-7 full turns from contact to get the valve not to flutter under partial boost. Im using the single spring mod., re-circulating. Nice whistle everytime...
WTB[SouthEast]: Greddy type S bov
Igaly1021
Jun 12, 2016 05:52 PM
gh0stch1ld
Apr 27, 2005 12:53 PM
