Rough idle when power equipment on
Old Apr 24, 2005 | 11:35 PM
bigjhoney's Avatar
Does anyone elses idle get a little funky when their defrosters on? Sometimes it will do it when to many things are using power at 1 time., or when the fans on at a redlight.
Old Apr 24, 2005 | 11:37 PM
JDM-Spec.com's Avatar
Take it to the dealer lol
Old Apr 24, 2005 | 11:40 PM
bigjhoney's Avatar
f the dealer, I figured it would be my new problem of the week since nothing else went wrong, just trying to get everyone elses insight.
Old Apr 25, 2005 | 12:25 AM
antonio010's Avatar
Yeah i notice it too especially when the AC fan kicks on. I just figure it's normal when there's an addtl load.
Old Apr 29, 2005 | 06:43 AM
evotino's Avatar
I asked the dealer about the same thing and was told the Evo uses a different type of AC compressor since it's a high RPM engine. Supposedly this makes it noiser and gives it a rough idle. Defrost uses the compressor so that would explain your problem.
Old Apr 29, 2005 | 07:22 AM
GOKOU's Avatar
I like to know why the compressor goes on when you turn on the heat. I'm thinking about removing that relay next winter.
Old Apr 29, 2005 | 08:19 AM
AD_LIB's Avatar
alot of ppl noticed an improvement with this after installing a grounding kit...i think that is about all its good for really.
Old Apr 29, 2005 | 08:22 AM
4-BNGR's Avatar
underdrive pulley would help
Old Apr 29, 2005 | 08:23 AM
Curt@MrLed's Avatar
Former Vendor
those parts use electricty, the more the draw, the more the alternator works, making the motor harder to turn, lowering the idle and causing a little rougher idle..
Old Apr 29, 2005 | 09:17 AM
umiami80's Avatar
Grounding kit helps alot. If you want, pruchase a HIGH POWER Generator for your car, one that gives the same volts but more amps. That'll work.
Old Apr 30, 2005 | 05:37 AM
evotino's Avatar
AC takes humidity out of the air and helps to defrost.
EVO9EMC
Apr 26, 2016 08:52 PM
mrdecrypter
36
Jun 7, 2014 06:15 AM
HN7
Sep 6, 2012 05:01 PM
Derek888
11
Dec 13, 2005 05:09 AM
ChillinEvoVIII
Jul 22, 2003 02:56 PM
