How to electronically eliminate ACD from 2005 evo???
Old Jul 10, 2005 | 05:20 PM
asasin79's Avatar
ok after a brief search i was able to determine that i wasn't wrong and the ACD is a constant 50/50 no matter were it is set. the settings only adjust the amount of time before the diff lets loose.
<<<<-------- 500 posts
Old Jul 11, 2005 | 09:50 AM
fsugatorbait's Avatar
More info?
Old Jul 11, 2005 | 10:30 AM
asasin79's Avatar
The Evolution 7 adopted a new Active Center Differential (ACD) that improves traction performance and steering response through corners. Replacing the viscous coupling-type with an electronically controlled multi-plate clutch differential, the ACD effectively regulates slippage in the 50:50 torque split center differential from free to lock-up to match driving conditions. Control is further optimized with a 3-way selector that enables the driver to override the automatic system and choose between Tarmac, Gravel or Snow modes for different surface conditions.
from http://www.geocities.com/alias_hery/MMC7.htm
Old Jul 11, 2005 | 10:46 AM
Chris@nolimitmotors's Avatar
yea basically ****ty for drag racing
Old Jul 11, 2005 | 03:28 PM
GEARS's Avatar
True it doesn't work that well for drag racing and at the bleeding limits of grip it can spook you pretty good in a turn.
The problem is in that the way the ACD duty cycles itself. It tends to have a little bit of lag and it can do it action kinda abruptly.
Jon@TRE
Old Jul 11, 2005 | 07:25 PM
kyJelly's Avatar
great info
Old Jul 11, 2005 | 07:30 PM
Spec'd's Avatar
If you had a JDM Evo, you would also have AYC to deal with.
Old Jul 11, 2005 | 08:03 PM
whiterexman's Avatar
Originally Posted by fsugatorbait
To the best of my knowledge, tarmac is 30/70 RWD, gravel is 50/50, and snow is 70/30 FWD.
ACD does not split torq. Our EVO is lock 50/50 the whole time.
Old Jul 11, 2005 | 08:04 PM
More info?
Here you go...
https://www.evolutionm.net/forums/sh...&highlight=ACD
Old Jul 12, 2005 | 05:48 AM
Originally Posted by whiterexman
Thanks for the clarification. I had been told that by a reliable source, so I assumed it to be correct. Live and learn.
Old Jul 13, 2005 | 07:40 AM
anjapower's Avatar
whoops...
Old Jul 13, 2005 | 07:42 AM
Originally Posted by anjapower
whoops...
Shouldnt you be on an Avalon board you groupie?
Old Jul 13, 2005 | 08:53 AM
Jon@TRE
O and BTW that 2004 Modified t-case you sold me is holding up wonderfully. Keep up the good work!!!
Evo47
Jun 15, 2016 07:38 PM
Migsubishi
For Sale - Part Outs
Apr 22, 2016 09:32 PM
desertsoldier22
Feb 17, 2016 08:51 AM
Ian0611
Dec 17, 2015 02:27 PM
yasir
Jan 27, 2007 06:58 AM
