Anyone Try Blitz Induction Cover
Old Apr 26, 2005 | 03:33 PM
EvO6-RS2's Avatar
Has anyone tried this filter setup..looks good. Can anyone give a review with dyno #'s if possible...Thanks
J
Old Apr 26, 2005 | 03:36 PM
Thegame's Avatar
Good post... I have one on the way from lancershop, but it's taking long. It must be backordered or something. I've only heard one good thing about it on socalevo.net. The guy said he liked it a lot and recommended it to people. As soon as it's on my car I can let you know how it goes. Probably won't have dyno numbers for you though. Anyone else?
Old Apr 26, 2005 | 03:40 PM
EvO6-RS2's Avatar
Thegame....That's cool please post your review anyways, thanks
Old Apr 26, 2005 | 04:46 PM
PeteyTurbo's Avatar
Just dis connect the top half of your air box, cut a bic pen into 4 peices,put the peices under the clips to hold the filter down and zip tie the clips together for added security..I don't have this setup on my car but I saw a car like this and it seemed pretty secure..Gives you the same results performance wise but looks like a setup suitable for an 86 stanza
J
Old Apr 26, 2005 | 04:56 PM
skiracer's Avatar
Here's a thread discussing my install:
http://www.socalevo.net/forums/viewt...litz+induction
No dyno numbers. Should be the similar to running your stock airbox without the top lid.
Old Apr 26, 2005 | 06:29 PM
taylor's Avatar
Did you have a cone-filter style intake prior to this? I'm curious as to how this compares in sound and power. Probably easier to tune though.
Old Apr 26, 2005 | 06:31 PM
skiracer's Avatar
I had a K&N dropin with the top lid removed and using copper wire wrapped around the OEM brackets to hold the filter in, so the results were similar. Just noticed the K&N was a bit louder than the Blitz dropin.
Old Apr 26, 2005 | 07:23 PM
EvO6-RS2's Avatar
PETEY_TURBO...that's a simple & affordable way..LOL
Thanks guys for your input
Old Apr 26, 2005 | 08:03 PM
Ted B's Avatar
I have the Blitz setup. It seems to work well, and before/after dyno testing shows that it does not appear to adversely affect the MAF signal like many cone setups do. It makes the compressor sound and BOV noise much more audible than the stock cover, which is designed to minimize noise.
It isn't cheap, but I found mine on Ebay for ~$50. I use the HKS panel filter with it.
Old May 3, 2005 | 09:06 PM
EvO6-RS2's Avatar
BUMP...for anyone else out there using this setup...
Jonno99
May 5, 2017 02:05 PM
Jonno99
Dec 8, 2015 10:28 PM
Beebo05
Dec 12, 2011 11:04 AM
evowizzler
Feb 26, 2009 06:58 PM
diameters
04-06 Lancer Ralliart How To Requests / Questions / Tips
58
Aug 28, 2007 09:10 PM
