Need Help!!
Old Apr 27, 2005 | 05:35 PM
go_evo_go's Avatar
Need Help!!
I recently took a road trip with my evo. As I was leaving the place I went to, the car stalled. Luckily I was pulling in to get gas. But that wasnt the problem. As I turned my car on again it was very difficult to start. Then my service engine soon light came on. I took it to a shop and they ran the computer and found that both the crank and the cam was misfiring. What could be the problem? He reset the computer and the car is runnng ok, although I can still feel a bit of a misfire. Also my oil pressure gauge is flashing the warning light. Could they be connected? Any info would help, but I ask that you know what your talking about. Thanks!!
Old Apr 27, 2005 | 05:46 PM
PVD04's Avatar
I don't mean to ask a stupid question, but you didn't mention it: did you check your oil?
Old Apr 27, 2005 | 05:48 PM
UT_Evo's Avatar
What exact codes were they? That would be able to get you more help.
Old Apr 27, 2005 | 05:49 PM
go_evo_go's Avatar
oil was fine, not sure of the codes, are there a lot of codes for what happened?
Old Apr 27, 2005 | 05:57 PM
UT_Evo's Avatar
well... you weren't exactly exact with your saying, and there's a lot of cam and crank codes
Old Apr 27, 2005 | 05:58 PM
timzcat's Avatar
You need to start with the oil pressure light flashing.
What is the pressure reading?
Old Apr 27, 2005 | 06:04 PM
go_evo_go's Avatar
Pressure reads between 75 and 110 depending on gears. No offense UT Evo but I have no idea what exactly exact means but thanks, I guess that I should have gotten the codes. So now that thats out of the way what should I do.
Old Apr 27, 2005 | 06:06 PM
dizzigital's Avatar
bring it in! and ask if you can watch so you know what to do next time. tell 'em you'll wear safety goggles and all and you'll make sure that OSHA doesn't catch you.
Old Apr 27, 2005 | 06:10 PM
timzcat's Avatar
It's flashing while driving with that kind of pressure?
How many miles does the car have? I would look at the spark plugs to see what they look like. I am guessing you feel the misfire under boost.
Old Apr 27, 2005 | 06:16 PM
go_evo_go's Avatar
Its flashing at idle, but not when Im drving it. It kind of seems like it drops the idle when im sitting there almost like its going to stall.
Old Apr 27, 2005 | 06:19 PM
timzcat's Avatar
Okay what is the oil pressure at idle, that is what I meant originally anyway.
Old Apr 27, 2005 | 06:23 PM
dizzigital's Avatar
oh shih... your mods didn't even register . . . if you can make it, take a trip to LA and visit Union Mitsu, they're cool. the MGR Jerome will take care of you. then hit up the beach for a nice tan and follow up with a fun night out on the town
Old Apr 27, 2005 | 06:30 PM
go_evo_go's Avatar
oil pressure is pretty low, well below 30. What should it be at during idle? I will do that dizzigital. I need to see the ocean again.
johnashton11
11
Sep 13, 2019 01:23 PM
nellynellz
Aug 23, 2011 06:58 PM
comatose721
Lancer Troubleshooting
15
Jan 11, 2008 10:28 AM
MrMejia
Apr 14, 2005 03:27 PM
skbydoo
Apr 26, 2004 03:12 PM
