Engine check light !!!
I have a 2003 evo 8 and 31k on it . I just had a new clutch installed and it runs great by the way but my engine check light just came on with a DTC P0300 meaning that there was a misfire in multiple cylinders...how can this be??? I'm going to inspect the ingnition system manana. but should I turn the light off and see if it misfires again? or should I keep it on? what should I do? what could be the problem?
yep do a search, their are tons of others with the same problem as you. It may have misfired, but many people have had it come on in error. I believe their is still no fix for it.
well i still have a stock ignition system , what I'm going to do is turn the light off and see if it comes back on .....im guessing if it does than there is a problem. **** poor 91 octane california gas could be more than half the problem!!!
Mitsu knows about the problem, there is a reflash to fix it.
https://www.evolutionm.net/forums/sh...ight=p0300+FIX
Originally Posted by MrMejia
hmmm....that sounds fishy, do u think a works reflash would fix that problem? I think I'll go drop them a line and find out.
https://www.evolutionm.net/forums/se...earchid=933396
d
iLLevo_
Aug 2, 2016 06:15 PM
evovin
Jan 3, 2008 07:27 AM
