HELP! my Evo is only pushing 14.5 lbs
Old Apr 28, 2005 | 04:10 PM
voodooutt's Avatar
I was doing a couple hard pulls today and all of the sudden im only pushing 14.5 lbs when my normal is 21
its not my boost guage, its reading fine.
I've checked all hoses, vacuum lines etc. none are whacked
my car runs perfectly, no hesitation.
I've tried turning my boost controller, but does not do anything.
what could be the problem?
thanks.
Old Apr 28, 2005 | 04:13 PM
ct9a gsr's Avatar
Check your vacuum lines that hook into your boost controller... also check for your I/C hoses (double checking doesn't hurt). Also try resetting the ECU too.
Old Apr 28, 2005 | 04:15 PM
Aby@MIL.SPEC's Avatar
the diaphram within the w/g actuator maybe damaged / torn...resulting in less boost.
Try disconnecting the boost line to the w/g actuator & see if you run any less boost. The only harm that can come from it is you run less boost.
Old Apr 28, 2005 | 04:20 PM
voodooutt's Avatar
do I cap it? or leave it to the open air?
Old Apr 29, 2005 | 04:43 PM
voodooutt's Avatar
it was the boost controller, the little bearing inside was acting goofy
Old Apr 29, 2005 | 04:46 PM
MrMejia's Avatar
I think its that venting it all out to atmosphere that seems to be the problem. sounds cool but driveability is definitely lost with atmospheric BOV's. try cappin it and recirculating.
Old Apr 29, 2005 | 06:48 PM
03BREvo8's Avatar
do you ahve a manual BC or a EBC.. if its man you may have a stuck ball.. take it apart and spray some wd40 in there..
Ferp
Feb 28, 2017 06:34 PM
2winscroll
Apr 19, 2016 07:04 PM
jcsbanks
12
Oct 29, 2007 01:21 PM
jaged
Jun 21, 2007 05:59 PM
evilution8
Oct 31, 2003 10:21 AM
