need some help.. only running 4 - 5 lbs boost
Old May 25, 2005 | 12:45 PM
  #31
chinto's Avatar
an up date looks like my cat was totaly fd up looks like it was totaly clogged causing soo much back preasure that it wouldnt allow the turbo to breath. thanks for all the help guys hopefully this will help somone down the road
to do a quick test if this happens to any one else just undo the two bolts holding the down pipe on and do a short run if you got boost its ur cat or somthn with the exaust. if not somthn with the turbo or wastegate.
dont run to long with the dp off or ull start melting plastic like i did for the sparkplug cover and cam belt / gears
