2.3 stroker + 6.5 TME
Old Apr 30, 2005 | 06:08 PM
mrmefodman's Avatar
Lightbulb 2.3 stroker + 6.5 TME
Has anybody done the 2.3 or 2.4 and the 6.5TME. The 6.5 will hold more boost up top where as that is the downfall of the stock turbo and the 2.3. I would imagine a super quick spool up and pull hard all the way to the top.
Old Apr 30, 2005 | 06:43 PM
marksae's Avatar
If the 16g wheel on our stock turbos have problems holding boost to redline on our 2.0L, it'll have an even harder time holding boost on a larger displacement motor.
Old Apr 30, 2005 | 06:48 PM
Widebandphillip's Avatar
tme will get overrun by the motor on the top end for sure.
Old Apr 30, 2005 | 06:56 PM
Vroompsh's Avatar
the TME isnt worth it from what i hear, and i can imagine it'd be too small and mismatched for the bigger displacement.
Old Apr 30, 2005 | 07:02 PM
chronohunter's Avatar
I think it would be cool to try, no it's not the ultimate drag combo but the low end torque and spool-up would be insane (for a street car). A 3071 would be a good option too...
Old Apr 30, 2005 | 07:11 PM
MalibuJack's Avatar
There's another thread somewhere dedicated to this where I explained what I thought would work well with this sort of combination.
Old Apr 30, 2005 | 07:51 PM
mrmefodman's Avatar
then what is my best option for a turbo that starts spooling under 2Grand.?
Old Apr 30, 2005 | 08:10 PM
MalibuJack's Avatar
You will definitely get a TME spooling very early with a stroker engine.. In the other thread it explains alot of this stuff already.. My opinion is although its a slight mismatch, you can get what your looking for. But you do sacrifice a little top-end power once your outside the efficiency of the turbo.
Old May 13, 2005 | 02:49 AM
Jakeg97's Avatar
does this mean that this thread is a repost? or a thread that should have never started?
Old May 13, 2005 | 05:18 AM
SuperHatch's Avatar
Smogrunner is building a stroker right now and he will be running a TME on it.
- Steve
Old May 13, 2005 | 07:05 AM
Smogrunner's Avatar
Yep.
Old May 13, 2005 | 07:55 PM
eric yong's Avatar
i am driving the 6.5 everything is just nice and its spooling a bit early somethimes
Old May 13, 2005 | 09:19 PM
propellerhead's Avatar
In other words, you're getting compressor surge?
