Just installed GSC 272/264 cams + Blitz BOV
Old May 2, 2005 | 10:30 AM
Dynofrk666's Avatar
Evo Police - The bov holds boost solid at 21 psi for me with no problems, i dont know why they would say 18 psi? weird.
Snap - It took me and a friend about 5 hours to install the cams using evomoto's guide, we really took our time and didnt rush through it to make sure everything went good. (we also didnt have the timinng belt tensioner tool which made it take alot longer). The install was really not that hard at all, just time consuming. I try not to open it up alot, i did a few 2nd gear pulls and you can really tell a huge difference, they definatly make you run rich though without a tune, you can even smell it in the exhaust.
4-BNGR - I am not measuring my AFR's, I'm kinda playing it safe and just driving the car like normal for now until i get a tune. I'm most likely going to upgrade the fuel pump sometime down the road but for now i'm just going to use the stock one.
Hope I helped
Old May 2, 2005 | 10:54 AM
berkel's Avatar
Sounds good.
BTW, I "think" cams are going to make you run leaner since they're going to flow more air... I think the car runs so rich you're probably ok. May want to consider a fuel pump before getting tuned. I've had good results with my Walbro...
The tune will make a very nice difference.
Take care,
FB
Old May 2, 2005 | 11:03 AM
Dynofrk666's Avatar
Yea i wasn't sure if it was rich or lean, i just assumed rich because i noticed my gas milage went down a bit. But i think i will consider a fuel pump just as a safety measure before i get the car tuned.
AutoMotoSports
Automotosports - Illinois
44
Dec 1, 2006 07:54 AM
AutoMotoSports
25
Nov 10, 2006 07:08 AM
negativeB
Sep 17, 2004 01:23 AM
Spankvo.03
Jan 11, 2004 03:37 PM
rt turbo
23
Jul 12, 2003 10:12 PM
