trunk mount batterys??
Old May 3, 2005 | 01:10 AM
Rcebowl's Avatar
i tired to search for it... but anyone any trunk mounted their batterys?? .. if not anyreasons why not... it's something i'm talking about to do to solve the problem of lack of room under the hood
Old May 3, 2005 | 01:25 AM
Compjoc's Avatar
Try searching under "battery relocation", there are lots under that phrase. Also Works is developing a whole kit just for the evo to relocate the battery to the trunk. But who knows when that will be available.
Old May 3, 2005 | 03:22 AM
plokivos's Avatar
i've seen one done. not too bad. re-routing the wires are the hardest part.
make sure you have the battery mounted pretty tight. Other than that, i don't see why not.
Old May 3, 2005 | 07:13 AM
quicknick's Avatar
Well how much room do you need. What about a small battery kit like from Buschurs?
Old May 3, 2005 | 07:46 AM
bolsen's Avatar
I bought my relocation kit from Summit.
Old May 3, 2005 | 07:47 AM
ultraflip's Avatar
can someone do a write up on this? i want to do this
Old May 3, 2005 | 08:30 AM
bolsen's Avatar
it's simple... just connect the new lead to the + and run it to the trunk. Ground in the trunk instead of engine bay.
Old May 3, 2005 | 09:00 AM
Bom's Evo's Avatar
i got mines mounted i nthe trunk. Black enclosed box thats not moving.
i got pictures soon.
Old May 3, 2005 | 09:20 AM
KevinD's Avatar
battery relocation is not really a good idea unless you need the large battery (i.e. stereo systems). the added weight in heavy gauge cables running from the front to the back really will negate any effect of moving the mass of the battery to the rear. go with a mini battery. you will save space, and it is much lighter then the stock battery not including relocation cables.
Old May 3, 2005 | 09:22 AM
damien ramirez's Avatar
exactly!
Old May 3, 2005 | 09:23 AM
timzcat's Avatar
One Battery cable from the trunk to the front is like 1 pound for 2 gauge.
No stereo setup either, I just don't like to get caught out with a dead battery.
Moving weight off the front and to the rear if done properly is a great idea.
Old May 3, 2005 | 09:24 AM
timzcat's Avatar
Here you go
https://www.evolutionm.net/forums/at...chmentid=21363
Old May 3, 2005 | 09:25 AM
VTECH8TR's Avatar
Moving weight off the front and the rear if done properly is a great idea.
Exactly .
Old May 3, 2005 | 10:21 AM
KevinD's Avatar
so that means my battery is 20 pounds lighter, plus 1 pound for the added cable of relocation. additionally, the mini battery sopposedly has more cranking amps then the stocker. and if worst comes to worse and the battery is dead, the car is a manual so i will just push start it
moving weight off completely is even better yet
Old May 3, 2005 | 10:49 AM
Bom's Evo's Avatar
the weight is moved to the back giving better f/r balance though.
