Just installed Buschur Exhaust......
Old May 24, 2005 | 05:57 PM
t3t418t's Avatar
Let's get some sound clips!
Old May 24, 2005 | 06:00 PM
lancealot72's Avatar
Originally Posted by 95GSXtoEVO8
I really like my BR exhaust, however I have one issue which I've already talked to DB about, and now I'd like to hear from some of you.
I don't like how far my exhaust tip sticks out. I have the magnaflow muffler. It seems the muffler will only slide so far on the cat back pipe, it won't go any further. I tried tapping it with a wood block and a hammer, it just won't slide anymore. The tip sticks out about 3/4" - 1" from the bumper, I would prefer it to be flush.
I have pushed it further into the hf cat, but I don't really want to go to far inside.
DB suggested sliding the pipe deeper inside the muffler, but when looking at the inside of the muffler, it's clear there is a lip inside of mine that won't allow the pipe to go any deeper. Anyone else have this problem with the magnaflow?
I noticed this problem as well when i put my exhaust on. It seems to just stick out barely too much, its almost a mood thing, somedays I love it some days it annoys me. I would however buy this exhaust all over again, I love it.
Old May 24, 2005 | 06:08 PM
EvoVec's Avatar
Good idea...this could be the excuse I have been waiting for to pick up a sawzall. Still curious if others have run into this though.
yeah when i put mine in i noticed that too so i took a hack saw to it and cut about 1 inch from it off. looks great now!!!!
and yeah butt dyno def notices good mod!
Old May 24, 2005 | 06:09 PM
EvoVec's Avatar
machevo.com has sound clips.
Old May 24, 2005 | 06:19 PM
Fred's Avatar
I have the same set up and love it/ I am having problems with a CEL coming in an out every so often. I took the car to AutoZone and the told me my cat has a problem. Anyone having the same problem? I have had the system for about a month now.
Old May 24, 2005 | 06:34 PM
95GSXtoEVO8's Avatar
I got a P0420 code (cat efficiency) after I installed this exhaust with the hf cat. I kept resetting it and it kept coming back. I ended up doing the mechanical 02 fix, do a search, worked like a charm. It's been many months now w/o the CEL.
Old May 24, 2005 | 07:53 PM
gonzo's Avatar
Yeah I had the same problem and Buschur sent me a fitting to goes inline between the O2 bung and the sensor.
Old Jun 18, 2005 | 08:23 PM
NJQuickness's Avatar
is it just mine or do some of you notice that the high flow cat has an arrow that points backwards.. the flanges and piping shows which direction it is clearly meant to go, but the arrow that points which way the exhaust gases are supposed to go point in the wrong direction. i called buschur and they said its ok, it'll work, doesn't matter, but then im wondering, why have the arrows then if it duznt matter? i feel like im gettin shafted here, anyone else??
Old Jun 18, 2005 | 09:22 PM
gonzo's Avatar
Mine points toward the rear of the car.
Old Jun 18, 2005 | 09:23 PM
David Buschur's Avatar
The arrow for flow has no effect on how the cat works, it is true. I promise. The vent tube inside, which we don't use on an EVO is the only part effected from the direction of the arrow. If you notice there is a welded up spot on the side of that cat, that is where the vent was, we weld them shut as the EVO does not use them.
The length issue......the pipe between the muffler and cat is also adjustable. Any of you that don't like that the tip sits out a little to far for your particular taste may want to push the pipe onto the cat/offroad pipe further. With the new exhaust you can PROBABLY even get away with moving the rear most hanger on the cat back pipe to the other side of the rubber for even more adjustment. I don't think it will cause any clearnace problems at the rear diff. We have a LOT of clearance in the systems.
Thanks for all the kind words guys!!
David Buschur
www.buschurracing.com
Old Jun 19, 2005 | 09:01 AM
sleet's Avatar
I love my BR TBE
Old Jun 19, 2005 | 12:39 PM
killr evo 8's Avatar
BR TBE is awsome! Best damn thing I bought for my evo!
Old Jun 20, 2005 | 09:52 AM
Glad you guys are happy. I am also really happy with our EVO exhaust, how can you argue with the weight, power and price? We did pretty good on that one.
Thanks again,
David Buschur
Aby@MIL.SPEC
100
Aug 19, 2015 08:04 PM
tscompusa
Nov 2, 2014 09:54 PM
hotkupa
34
Nov 29, 2011 08:39 PM
cinek
Nov 3, 2007 07:28 PM
Scuba2001
10
Jun 29, 2005 07:32 PM
