Clutchmasters stage 4 clutch? HELP!
Old May 10, 2005 | 09:42 PM
topnotchevo's Avatar
i beleive they have dfx clutch out now that i r n d ..very nice piece, but u have to get a flywheel
Old May 10, 2005 | 10:13 PM
Wrench's Avatar
Originally Posted by plokivos
I have ACT, my GF has ACT, my friend is getting ACT, his friend is getting ACT. The guy with the RPS clutch is changing it to ACT.
with minimal mods with streetability (say 350whp or so daily driver), you can't beat the price and driveability of ACT.
I approve this message.
Which guy with the RPS is changing It?
tke 413,
All aftermarket clutches have their issues.
Twins and triples have floater(s) that can grab slightly when disengaged and can cause the tranny to occasionally feel notchy, and they may work the sincros harder. They also have a narrower engagement band that makes slow roll outs a challenge, especially when hot. They can also groan indiscrimently. $2000 - $3500 installed iirc. Exedy, ATS, RPS. Go with one of these if you are going to make big power (+ 450 crank hp IMHO) which you look like you are close to.
Twin metallics warp and wear out fast with high HP and can warp then chatter
Singles can be heavier and may have issues pulling out of gear at high rpm $1000 - $1500 installed - guessing. I've heard the ACT being recommend by the transmission guys, probably because of the floater issue with the twins.
All will wear out if you slip them and do a lot of launches, they just hold better.
Find your favorite tuner and use what they've used if they've used it for more than a few months.
I don't think there is a perfect solution, so you may end up trying them all!
Old May 11, 2005 | 12:38 AM
plokivos's Avatar
a guy in alabama.
Old May 11, 2005 | 08:23 PM
ACTman's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=126768
Old May 12, 2005 | 06:05 AM
tke_413's Avatar
New Question
I already read that whole thread which made me lean towards the ACT, but I posted this thread to maybe get some feedback on the Clutchmasters which I haven't heard much about. It's looking like I'll be ordering an ACT now though. The place doing the install said I don't need a new flywheel, he will just resurface my stock one. Any comments on this?
Old May 12, 2005 | 06:50 AM
mump's Avatar
i just put in an ACT and love it. The guy who did mine said not to get a new flywheel. He just polished some of the marks (my flywheel didn't look bad at all) and put it back together. He also put in a SS clutchline at the same time. new lightened flywheel or your old, shouldn't matter.
Old May 12, 2005 | 09:10 AM
bolsen's Avatar
Yes, resurface it. It's only $30
Old May 12, 2005 | 09:12 AM
ACTman's Avatar
It depends on how bad the flywheel is. Check for cracks at the clutch surface. Lay a straight edge on the clutch surface and see how warped it is. They always try to cup away from the clutch when they warp so you will see daylight between the straight edge and the flywheel that gets bigger toward the center. If you can get a .040" feeler gauge betwen the straight edge and the flywheel I would probably replace it.
Old May 12, 2005 | 06:38 PM
hello..anybody hear..u need a flywheel..a must have..evo dsm flywheel = bad design..to thin..i ve been threw 2 and 6 clutches in r n d ..DFX blows away da comp..i blow up clutches for researh..dont ya love da smell..if u dont replace the flywheel , u will be replacing ur disk..learn from my exp..
Old May 12, 2005 | 06:58 PM
bolsen's Avatar
Good thing you are paid for blowing up clutches and not for data entry
Old May 13, 2005 | 04:13 PM
i see ur bored and dont have a clutch flywheel..1020 boring life posts..get one
Old Jul 2, 2011 | 10:03 PM
mitsevo03's Avatar
I have a clutchmasters stage 4 in my car now and its locking me out of gears when i drag. Its **** compared to an exedy. I am now going with an exedy twin hd
Old Jul 3, 2011 | 08:16 AM
blknblubkrdude's Avatar
The clutch is probably fine, it sometimes takes a while to get the clutch adjustment dialed in. If not, something got tweaked during the install.
Old Jul 3, 2011 | 08:23 AM
Evo3573's Avatar
I have had act hd street disc and cm stage 4. I hated the cm stage 4. I love the act hd its holds alot of power and is awesome to drive and can last way longer than any twin disc. I am currently at 492 whp and it has held up pretty good
Act hd street disc is what I would go with
ronitlancer
245
Oct 6, 2011 12:26 PM
FiReTRuCKoZ
Lancer Tranny/Drivetrain Tech
Jan 25, 2011 07:11 PM
evascst
Feb 3, 2010 10:19 AM
honda-guy
27
Aug 24, 2009 11:07 PM
evoamac
16
May 13, 2009 08:54 PM
