Borla turbo manifold
Old May 11, 2005 | 08:12 AM
EvolManiac's Avatar
Cool Borla turbo manifold
Does anyone know if they come with Anti Lag System ports? If not can someone point me to a manufacturer that makes those, that doesnt compramise the quality and for a good price.
Old May 11, 2005 | 08:21 AM
evo 8 ya's Avatar
I don't think borla comes with the anit lag holes. but this manifold does
http://www.dnperformance.com/evo.html
Old May 11, 2005 | 08:22 AM
trinydex's Avatar
first off if you're gonna try to use antilag on a tube mani you're gonna break something. second of all if you wanna run antilag with a tube mani that doesn't have bosses... just use egr.
egr antilag is the method of feeding oxygen back into the mani by tapping the cold side of your turbo and connecting it to your egr valve so that when the egr recircs the exhaust gases you will also get fresh air into your exhaust manifold. this will give more than enough air to get your bang bang going.
Old May 11, 2005 | 08:24 AM
evo 8 ya's Avatar
he's from japan. It's stock on his evo IV over there.
Old May 11, 2005 | 08:32 AM
trinydex's Avatar
uhm.... what i said still holds... he can easily take off the bosses from his mani and disconnect it from the bov if he wishes to run the borla or any other mani. running egr air feed is just a matter of custom fabrications (drilling a hole, running a line) and tuning which he should be fully prepared to do anyway.
Old May 11, 2005 | 08:50 AM
EvolManiac's Avatar
hmm, too much work to drill hole, and not enough tools, i left them in the states, too heavy to bring... hey EVO 8 YA will the quality of the tubes from dnperformance hold up to the heat?
Old May 11, 2005 | 08:53 AM
JDM-Spec.com's Avatar
I have it on my car, it doesn't came with anti-lag ports. It is only made for the USDM evos.
Old May 11, 2005 | 08:57 AM
EvolManiac's Avatar
Will the Turbo Manifold from DNperformance work?
Old May 11, 2005 | 09:05 AM
EvolManiac's Avatar
Thanks Evo 8 YA
Old May 11, 2005 | 09:45 AM
EvolManiac's Avatar
I saw the Megan Racing Turbo Manifold, it comes with the ALS ports, does anyone have experience or info on the quality and gains on that?
Old May 11, 2005 | 09:50 AM
redevo561's Avatar
ive heard some good things about that manifold they have mention better spool up and top end was alot better but that all depends on supporting mods as well
Old May 11, 2005 | 10:00 AM
EvolManiac's Avatar
what have you heard on the quality, ive read a lot about manifolds cracking in half and so forth, does it have a warranty on it also
Old May 11, 2005 | 01:32 PM
EvO6-RS2's Avatar
I got a DNP & Megan Racing manifolds, the DNP didn't come with ALS/EGR ports for the JDM spec EVO's...but the Megan did have the ports for ALS/EGR.
Don't buy the DNP, buy the Megan if you want to stay with they stock egr/als setup. And the Megan's CHEAPER!! It looks well built as well.
Old May 11, 2005 | 01:39 PM
djtmotorsports's Avatar
Wait for the GT Spec header!! It will be on the market in the next couple of months. It will have the anti-lag ports. I have seen pre-production pieces and it is gorgeous. If you have time, wait!
Old May 11, 2005 | 11:23 PM
EvolManiac's Avatar
thanks
