Can this be true and/or Safe?
Old May 16, 2005 | 05:49 PM
  #31
Precision Dyno's Avatar
Originally Posted by 03BREvo8
that 24-25 psi.. just pump gas right.. with alky its more like 27-28
With alky you can be around 27-28. That not only helps cool the charge down, but it will also let you run at that A/F ratio with less of a chance for detonation. Alky is a great tool to use when cylinder and charge temps in the evo can create undesired circumstances while in that boost range.
Old May 16, 2005 | 05:53 PM
  #32
Originally Posted by Ted B
One can run as much boost as he likes (e.g. 30 psi spikes) with the stock injectors, so long as the hp level at that point does not exceed the injectors' max flow rate.
Unfortunately with the datalogging we have done on pump gas and stock injectors, at peak torque, we see an A/F of about 12.5-12.7:1. At that point we don't think the engine is safe. Once we installed the new injectors we flatlined across the boost range at 11.5 and no detonation. Even with some increased timing lead we saw tremendous gains in the midrange when running a little richer.
Old May 16, 2005 | 05:59 PM
  #33
Curt@MrLed's Avatar
Former Vendor
you are correct sir.. i have hit 29 twice, when the hose blew off... damn rvm i/c pipes...
Originally Posted by Jorge T
Actually it is a boost line, not vacuum and if you disconnect it your turbo will overboost.
When EBCs are turned off it maintains the solenoid shut and directs all boost to open the wastegate.
Old May 16, 2005 | 06:06 PM
  #34
Originally Posted by SuperHatch
You are correct in saying that the cylinders are filled via boost pressure and not vacuum created by a downward traveling piston. However, the boost pressure measured at the intake manifold is the pressurized air that wasn't able to get into the cylinders. An engine with higher VE can flow more air at a lower boost pressure than an engine with low VE at high boost pressures. Assuming that the dynamic pressure at BDC before compression is the same as the reference pressure measured at the intake manifold can be and often times is a bad assumption...
- Steve
Well I was more leaning toward the fact that vacuum is a misnomer. Negative pressure is created and thus positive atmospheric pressure or boost will push the charge into the cylinder.
The comment about increased VE at lower boost pressures seems to be true with NA engines more than a forced induction engine. Especially one with identical air flow capabilties. Meaning same cams and port work etc.
Dynamic pressure will vary with many things including static compression, load, rpm, boost pressure, cam profile, stroke etc.
For the most part I agree with your post.
Old May 16, 2005 | 06:31 PM
  #35
andrew20195's Avatar
Originally Posted by Precision Dyno
No it has not been only for testing. The stock turbo has been holding up very well up to now.
Wow, I'm really surprised. You are spinning the hell out of that turbo, and the best efficiency you could hope for at that PR would be 65%. Any idea what your before/after intercooler temps are?
Old May 19, 2005 | 03:35 AM
  #36
Charliebrown's Avatar
Charlie brown,
An engine doesn't breathe air in. Especially under boost. It is pressurized regardless of boost pressure or atmospheric pressure.
If the air was to "back up" then you would see a restriction somewhere. If there were a restriction then the turbo may continue to boost 30 psi at redline or close to it. As an engines rpm increases the amount of air being processed decreases after peak torque. That would definately decrease the life of the little turbo.
You are right that the turbo will push a certain amount of CFM, BUT what does cubic feet per minute have to with compressor efficiency?
Timing is timing. There is an ideal figure for every load and rpm. It doesnt matter if it is "retarded" or advanced. It is a figure that is calculated to provide the most amount of power without sacrificing reliability in the quality of fuel being used. Advanced timing does NOT give you more power. The proper timing lead (whatever number that may be) along with the proper parts of air and fuel do.
as for the timing, throw yours back 15 degrees and tell me that you are making the same amount of power and that the engine speed accelerates just as quickly . at 30 psi on pump gas I would hope that you are running less advance than you would at 20, at least for your engines sake.
An engine does breathe air. under boost it may be getting force fed but nevertheless air is waiting for the intake cycle to happen. the faster and more often the intake valves open---- the less air you have pressurized waiting in the intake manifold.
i'm not worried about compressor efficiency more so about air efficiency . if you are allowed only 500 CFM of air no more, no less, it is better to get it at a cool 21-23 psi rather than a hotter 30 psi. And one way to get that pressure up to 30 psi is to make the engine accelerate less quicky. And one way to to that is by having ignition timing retarded far less than would be ideal either by tuning or by knock sensor correction
Old May 19, 2005 | 05:55 AM
  #37
Hiboost's Avatar
Time for someone to compare a Dyno sheet on the same car at 21 PSI versus 27 PSI versus 33 PSI using any tuning tricks in the book to make it work.
Bman513
Sep 13, 2016 01:12 PM
bafhoops89
Jan 27, 2012 01:29 PM
jrod4484
Apr 8, 2011 06:44 AM
Spish
May 19, 2008 08:59 PM
Turbojunkie
Apr 11, 2006 08:51 AM
