Boost Control PSI Level
Yea, right now everything is just bolted on and tuned stock, but I just got a manual boost controller and wanted to turn the boost up without messing things up....Also, what PSI would I need to get head studs at?
Get it tuned first. Have you logged the car yet? Untuned on 91 I wouldn't suggest going over 19.5 PSI. 21 would be absolute max untuned on 91. That is for me at least.
You do have a boost gauge right? I realize that there is an itch to install the MBC and crank up the boost. But, resist that urge and just get a good tune first.
^+1. I would get a tune before messing wit the boost or you might regret doing so. Do you have a wideband? If so u could ever so slightly mess with the boost as long as the afr stays in check.
evil03
14
Jul 24, 2020 05:22 AM
