cobb ap... not hitting target boost psi?
Old Nov 23, 2010 | 11:58 AM
evil03's Avatar
Hey guys i now just installed my cobb ap... running stage 2 map for ACN91
thats the specs
"Stage2 ACN91 RAv100 - Intended for an otherwise stock 2009-2010 Mitsubishi Lancer
Ralliart vehicle with a full turbo-back exhaust system with at least one high-flow
catalyst installed, STOCK INTAKE SYSTEM, and STOCK INTAKE FILTER ONLY designed for
Arizona, California, and Nevada 91 octane fuels. Boost Targets: ~20psi peak boost
pressure tapering down to ~13psi by the 7100 RPM redline, +/- 1.5psi."
I am hitting 15.5psi to 16.7psi max....and tapers down to 14.3psi to 14.6psi
any one can tell me why? i have checked for boost leak... and checked all my lines... even my hard pipes..
thanks
evil
Old Nov 23, 2010 | 01:50 PM
Geereg's Avatar
What does it do with the stock map?
Old Nov 23, 2010 | 04:19 PM
evil03's Avatar
act like a stock RA... ??
Old Nov 23, 2010 | 05:25 PM
Geereg's Avatar
The point of the question was that with the stock map the boost target is higher than you are reaching. So, if it reaches the stock target it's not a physical problem.
Old Nov 23, 2010 | 05:45 PM
evil03's Avatar
ok then the stock map spikes at 15psi and tapers down to about 13.5psi
Old Nov 23, 2010 | 11:47 PM
Gman4ver's Avatar
my stock ralliart was peaking at 18psi and tapered down to around 10psi-ish at the red, so even your stock numbers seem to be a bit low. i would do a boost leak test so you can know for sure. 80% of people that have problems with there boost have a leak. As far as the cobb ap, i went with a custom tune so i really can tell you much about that but let us know what happends...
Old Nov 24, 2010 | 02:07 AM
gaabbee's Avatar
there was another member on here that had a problem with cobbs stage 2 tune...i would call cobb or get in touch with this other guy...all i can remember is he has a gray ralliart and lives around rode island....
Old Nov 24, 2010 | 04:44 AM
Slee256's Avatar
His username is: SOG RA
Old Nov 24, 2010 | 10:20 AM
evil03's Avatar
any pointer how to start a boost leak test on a ralliart ??
Old Nov 24, 2010 | 06:00 PM
Slee256's Avatar
http://www.youtube.com/watch?v=uixdw49Km4s
Old Nov 25, 2010 | 07:49 PM
disturbedfan121's Avatar
doesn't the stock RA BPV leak at like 12psi? hence why everyone upgrades to evo bpv?
Old Nov 25, 2010 | 08:54 PM
evil03's Avatar
Originally Posted by Slee256
will hunt for boost leak this weekend!
Old Jan 10, 2011 | 04:56 PM
SOG RA's Avatar
Hey buddy, sorry to hear you are having that issue. Send me a PM and I will tell you what I figured out with Cobb to save you the trouble...because it is a huge pain in the ****.
Old Jul 23, 2020 | 10:27 PM
Donnie oac's Avatar
Hello i have same proble my boost stuck on 11 psi
Hello i have thesame problem my boost hitting 11 psi only on 3rd gear full doesnt seem i have any boost leak or something because i check it hope you help me
Old Jul 24, 2020 | 05:22 AM
RalliFast's Avatar
Bumperino
-H-
11
Jan 23, 2020 02:37 PM
johnjodoinevox
Cobb AccessPORT
Sep 27, 2015 12:45 PM
H8ted1488
Nov 9, 2010 08:23 PM
sgtpruitt
17
Jun 1, 2009 11:46 AM
mooserov
13
Mar 10, 2009 06:48 AM
