Running 26psi safe?
Old Aug 13, 2016 | 01:45 AM
Bman513's Avatar
Running 26psi safe?
Is it safe to run 26psi on stock everything?
Old Aug 13, 2016 | 05:34 AM
If the motor has the supporting mods (pump,injectors,exhaust,intake,boost control,fuel & of course, the tune) for sure its safe
Been on 27psi (E85) for 6 years (stock internals)
Old Aug 13, 2016 | 03:30 PM
Bhsj13's Avatar
I'm around there on 93 octane. Tuned a little rich with more timing. It's possible depending if your tuner can do it.
Old Aug 13, 2016 | 03:51 PM
ardevas09's Avatar
you're not just turning up your boost all ***** nilly, are you?
Old Aug 14, 2016 | 09:39 AM
Teal2nnr's Avatar
Lots a variables. It can be done depending on the set up, tune, and what type of fuel you're running.
Old Aug 30, 2016 | 05:57 PM
GordonVIII's Avatar
I ran a stock 8 turbo at 26psi, tuned on 93, with supporting mods. Never had any issues, it was a blast.
Old Aug 31, 2016 | 06:42 AM
Rossi_24's Avatar
ill be getting tuned this Friday @ CBRD from Chad, looking to run 25-26 psi with mods in sig. From what I read and discussed you can safely run 26psi. Thing is if you brutally beat the car then I can see it not being good, however I somewhat daily my Evo and mostly drive normal you can say lol, but do love to tear up an on ramp here and there.
Old Aug 31, 2016 | 09:50 AM
lancerrally45's Avatar
28 psi here plus the E85. 124k on the clock. Complete stock long block.
Old Aug 31, 2016 | 10:04 AM
Pal215's Avatar
That's what I did as well without any problems.
-pal215
Old Sep 1, 2016 | 08:37 AM
nemsin's Avatar
Its more about the tune and how you run the car. A stock everything street tune might boost to ~26 then taper down to ~23 up top. A stock everything track tune would be more conservative (since it has to account for higher expected egt's).
No way I would run a stock evo at a flat 26psi on pump gas for a 20min track session.
Old Sep 1, 2016 | 01:51 PM
Rossi_24's Avatar
I agree, if your going to track your car then its most likely not safe ive seen most run around 23-22. However street tune you can run up to 26 since you'll mostly be "cruising" and ya know obeying traffic laws lol. But maybe you'll need to pass someone or see a nice on ramp and you can rip it with no issues, that being said tho that the tuner knows what hes doing.
Old Sep 3, 2016 | 11:22 PM
4b11slayer's Avatar
Head studs.
Old Sep 4, 2016 | 12:59 AM
pakotoke's Avatar
i run 28psi stock internals except some gsc s1 cams, on pump gas...
Old Sep 4, 2016 | 02:12 PM
Teal2nnr's Avatar
Really? On 91? Are you running meth or something? At that point the turbo must be pushing so much hot air I can't even see the few extra Psi being worth it.
Old Sep 4, 2016 | 02:32 PM
pakotoke's Avatar
no meth or nothing it puts down 320~330 to the wheels,and this set up was from the previous owner., im guessing he wanted big numbers when tuned to 85 since he said it just needs a tune,i hit 27 pounds and kept going back and forth from 26 to 27..on a cold night it does 28 to 27
sorry for wall of text
