How much boost
Old May 16, 2005 | 09:19 AM
timzcat's Avatar
Have fun adjusting it everytime it gets warm or cold out.
With a EBC you have more control over how boost comes on.
Old May 16, 2005 | 01:08 PM
CeeNiK's Avatar
i live in florida its always warm!!!!
Old May 17, 2005 | 09:56 AM
NapervilleEVO's Avatar
night and day temperatures make a difference as does humidity levels. 10 degrees and you could be +/- .5 PSI. how much boost can you run with a 255 walbaro? if i get a fuel pump should i get injectors? injectors plus walbaro how much boost?
Old May 17, 2005 | 12:43 PM
fsugatorbait's Avatar
If you change the size of the injectors you will need to have the car retuned. In 5th gear with the Hallman pro MBC I have it set to spike to 22 and taper to 20.
