Need: Stroker + Turbo?
Old May 17, 2005 | 07:11 PM
mikiblueeyes's Avatar
I am in the process of Bringing up HP & TQ on my evo. 300HP doesnt cut it
anymore.
I was looking at ATP kits and AMS Stroker.
Does anyone knows what Stroker kit and Turbo combination would equate to Stock spool?
Old May 17, 2005 | 07:12 PM
plokivos's Avatar
why don't you use a stock turbo and engine and make 400 whp with alky injector at 28psi?
along with fuel pump and bigger FMIC?
Old May 17, 2005 | 07:19 PM
Looking at 400 HP with no ALKY kit, and 450HP with it.
Also Stock spool is a must.
Old May 17, 2005 | 07:24 PM
housedj's Avatar
Thumbs up
anymore.
just bolt up a 4G64 block to your head, get some pistons & stuff, w/stock turbo instant POWA!!!!!!!!!!!!!
Old May 17, 2005 | 07:29 PM
Was just looking at that from RMR, cost about $4500 plus core , labor & shpping
=$7,000+ thats without turbo) +3,000 turbo=10LARGE
So the plan was to get the stroker and the turbo,
Just need opinion which one would work nicely and spool early on the stroked engine?
Old May 17, 2005 | 07:53 PM
03BREvo8's Avatar
just have Buschur do a 20g Upgrade to the evo 16g for 500whp
Old May 17, 2005 | 07:58 PM
is that 20G turbo on 91 Octane? 2500-3000rpm spool?
Do you know by any chance the Spool of that 20G?
Thanks
Old May 17, 2005 | 08:05 PM
03BREvo8's Avatar
its identical looking to the 16G its a conversion.. and i beleive the spool is somewhere in that neighborhood considering that the evo 16g flows 2lb/min less than a 20G
Old May 17, 2005 | 08:23 PM
WOW, sounds good, need to do more research on that 20G.
If anyone have some more info, Keep it coming
Old May 17, 2005 | 08:28 PM
03BREvo8's Avatar
look on here for a post from buschur ,not quite shore which one its in .
Old May 17, 2005 | 08:46 PM
looked already and it looks like 20G is now 21G and that thing spools slow and only give 10-20HP
Guess will have to get 3071 to make at least 50HP and keep stock spool.
Wonder how 3071 and 2.3 Stroker engine would work and what HP can I get on 91 Octane??
Old May 17, 2005 | 09:23 PM
rlazer5000's Avatar
AMS has a really nice stroker kit. As for a turbo, both RNR and AMS have group buy turbo kits going on right now. If ur looking for some serious power, the GT35R from either vendor is freakin sick with a stroker kit. If u wanna maintain a somewhat higher than stock spool, check out the GT3076 or the GT3071. Haven't heard many positive things about ATP, but AMS and RNR have amazing kits and they're quality is top notch. You'll have to fork out some extra cash for the AMS kit though, so the decision is up to u! Good luck bro!
Old May 17, 2005 | 09:41 PM
Thanks a lot for the info!!!
Will probably go with 3071 and stroked engine, However i hear that this setup chokes the turbo??? Is it true or BS?
Old May 17, 2005 | 10:06 PM
rlazer5000's Avatar
Thats a crock of ****, the stroker should actually improve overall spooling of the turbo cause it's a bigger displacement engine. I don't know who got that idea......i don't even know how u would choke the turbo unless u boosted at like 35 psi or something.
Old May 17, 2005 | 10:07 PM
plokivos's Avatar
i heard gt30 and gt 35 hybrid could actually do what you want.
you have to have it custom made... I'll find some more details about it.
I actually like the stock turbo setup with 10.5 hotside with titanium turbine idea.
this gives you better hp range/tq range as well as decreasing inertia of the turbo spool lag, which in turn makes you more hp at faster spool up.
