Best Hi-flow Cat?
Old May 18, 2005 | 02:56 PM
91z28-350's Avatar
The UR cat would be the first choice.
Watch what cat-back you are using, make sure the flange will fit properly...
Old May 18, 2005 | 03:17 PM
JSYEVO's Avatar
does the UR cat fit the HKS hi power?
Old May 18, 2005 | 04:27 PM
johny719's Avatar
will the UR cat or random tech and the RMR one fit the Greddy TI and Helix DP?
Old May 18, 2005 | 04:54 PM
91z28-350's Avatar
The UR cat is a standard 3" flange. If your cat-back has a universal flange (slotted bolts) and is a 2.5 flange (same size as stock), you're going to have problems.
Old May 18, 2005 | 04:57 PM
GreedMOTO's Avatar
Originally Posted by negativeB
my helix hf cat never throws a ses. maybe you really need to service your engine?
My Helix HFC DID throw a Service Engine Soon lite...thank god I have a code reader/scanner/erase under my seat...
stupid emission controls....
Old May 18, 2005 | 05:05 PM
mump's Avatar
that is what i have. fits fine. going to replace it with a UR testpipe though, for no other reason than me and my evo are probably heading over to Korea in a couple months and over there seems the more pollution the better.
Old May 18, 2005 | 05:08 PM
auto2nr1's Avatar
i have the ur cat and the hks exhaust it fits fine.
Old May 18, 2005 | 05:10 PM
nefblkevo's Avatar
to the dude with the Greddy Ti Helix downpipe, go w/ the Helix HFC, fits perfect.
Old May 18, 2005 | 05:19 PM
dohcvtec's Avatar
i have the Works HFC, not sure on its numbers but works great!
Old May 18, 2005 | 07:16 PM
JSYEVO's Avatar
someone said the 30th ann hi power tapers down to 2.5" when it meets the cat and so i might have a problem fitting a 3" cat? how did you guys do it?
Old May 18, 2005 | 07:32 PM
marksae's Avatar
I have a WORKS 3" high flow cat mated to my hks 30th cat-back. The gasket still allows a seal, so I have no leaks. Since the flange is pretty thick, I plan on porting out the flange giving it a little taper, so the transition isn't so abrupt.
Old May 18, 2005 | 07:38 PM
JSYEVO's Avatar
damn, so it does taper, but it doesnt affect the fitment. i guess ill have to a look for a new exhaust.
Dr.Sound
23
Nov 5, 2008 09:45 AM
Sheng_33
May 21, 2005 05:12 AM
SinCityEvo
Oct 8, 2004 09:28 AM
Gruppe-S
14
Sep 10, 2004 11:02 PM
Gruppe-S
Gruppe-S Engineering - California
Aug 30, 2004 01:19 PM
