Injectors / Fuel Pump
Old May 20, 2005 | 02:46 PM
fuzzychi's Avatar
Ok so I got some HKS 264/264 cams but I am not sure if I should have them installed or get injectors and a new fuel pump before installing them. And when is it necessary to get new injectors and fuel pump?
Old May 20, 2005 | 02:53 PM
Kevine326's Avatar
bigger turbo=pump + injectors. You have a SAFC 2 so you could always for safety get a a set of 660's and a 255 and tune it out but your dont NEED it now. If you intend on going further or getting a stand alonge yes shop around and get the pump/injectors.
Old May 20, 2005 | 03:02 PM
Kuba23's Avatar
You need a Fuel pump ASAP i recommend changing the fuel pump as soon as you put a first mod on your car Especially with cams injectors you dont need but fuelpump YOU DO.
Old May 20, 2005 | 04:05 PM
Zeus's Avatar
Pump always... injectors no depending on your tuner.
Old May 20, 2005 | 07:18 PM
03BREvo8's Avatar
If youd read his mods youd see that there is a STOCK turbo... So all you need is the pump .. Injectors arent needed on the stock turbo with either a tune or a SAFC... And you do need a PUMP if you put in the cams.. you wont be able to tune it right if you dont have it.
Old May 20, 2005 | 10:52 PM
Warrtalon's Avatar
Actually, he recommended the injectors specifically because of the S-AFC. They really are a wise mod when tuning with an S-AFC, because you pull out a lot of fuel and make a lot of power. With a flash, it's not as helpful...
Old May 21, 2005 | 12:53 AM
EvoPanda7's Avatar
will injectors add hp... i know i dont need them till prob 350whp but i was wondering if they would add hp
Old May 21, 2005 | 06:22 AM
Bom's Evo's Avatar
just follow the BR stages.
Old May 21, 2005 | 07:18 AM
Warrtalon's Avatar
No, they don't "add" hp, laugh. They just allow you to flow more fuel to support higher hp levels.
