jet fuel? in a evo
Old May 21, 2005 | 01:27 PM
Massevo8's Avatar
100 low lead? in a evo
Well i was just wondering, a friend of mine runs it in his supra allot. Its called 100 low lead its not unleaded which makes me think twice about it. You can get it at personal air ports. Gas prices for 93octain are around $2.35 100 low lead is about $2.99 i have ran 100 unleaded which i can get down the street from me but its $6.99 a gallon and the car loves it but my wallet doesnt . so if i can get a few honest opinions that would be great thanks
Old May 21, 2005 | 01:29 PM
Want to Evo's Avatar
It will destryoy your oxygen sensors and catalytic converter (if you have one).
EvoLoverForever's Avatar
seriously... thats methane... go ahead ... but remember the small text....
im am not to be held responsible for damage done to anything of your car
Old May 21, 2005 | 01:33 PM
j8's Avatar
j8
This has been discussed a few times here is a link.
https://www.evolutionm.net/forums/sh...t=avation+fuel
Old May 21, 2005 | 01:38 PM
housedj's Avatar
Thumbs down
keep in mind, running leaded fuel will require you to change your O2 sensors at intervals of every 50 hours driving time. check my post in the west region about 109 octane unleaded if you need a fuel alternative that is safe for your car.
Old May 21, 2005 | 03:09 PM
Massevo8's Avatar
thanks that helped i gues ill just get raped 7$ a gallon on weekends and at the track
Old May 21, 2005 | 03:31 PM
EVOLUTIONIZE's Avatar
Av gas? Everyone uses it down here (MIAMI), from stangs to porsche twin turbos heck i used it a couple of times on my eclipse, But remember to mix it with 93, 50 hours driving? Maybe on 100% 100Oct it will kill ur oxygen sensors, i heard by itself it could kill ur fuel pump because of the lack of lubricans and additives, But i know of a lot of ppl using it on a weekly basis, Mixed with 93oct that is. Its the only close gas staion around here with anything higher than 93 unless you buy c16 $$$$$ from any local shop...
Old May 22, 2005 | 07:57 AM
althemean's Avatar
100 low lead is low lead by avgas standards, but not by car standards. dont let that fool you.---Aircraft Tech but lyou can run it. I used to do it sometimes in my 83 280zx and never encountered any probs.....that car had no cat though.
Old May 22, 2005 | 08:34 AM
badlooser's Avatar
I dont know if it is true but I heard that you can run a pump gas map and just turn the boost up.
Old May 22, 2005 | 08:40 AM
DEV0LUTI0N's Avatar
I run Sunoco GT 100 all day, every day with no problems (yet). No cat so no worries...O2 sensor(s)? No worries...easy enough to replace if necesary. If you are driving an Evo, then toss practicality out the window...otherwise trade it in on a hybrid and go hug a F*ckin tree!
Old May 22, 2005 | 08:42 AM
DEV0LUTI0N's Avatar
...P.S. fuel pump? No problem...Walbro 255..$85.00
Old May 22, 2005 | 09:21 AM
CeeNiK's Avatar
how long have you done this for?
Old May 22, 2005 | 09:23 AM
CeeNiK's Avatar
they have a gas station here that runs Sunoco GT 100..is it low lead how that guy was talking about? or unleaded? and just incase is it safe to mix with 93?
Old May 22, 2005 | 09:34 AM
althemean's Avatar
sunoco gt100 is an unleaded fuel. i run it in my evo and dilute the gas about 3gal of 100 to 11 gal of 91 gives me 92.9 octane. cost effective to get 93.
Old May 22, 2005 | 09:38 AM
althemean's Avatar
by the way 100Low Lead is avgas. meant for piston powered aircraft engines that are aircooled, run on carbs, have no cats, Avgas is not to be mistaken with jet fuel which is really close to kerosine or diesel. The lead it conatins is tetra-ethyl lead, i think around 3.5ppm. It is a blue color. 100 octane avgas is red in color and has around 7ppm TEL content. I dont work with piston powered aircraft so the lead content numbers may be off but I am sure its close.
