Do i need a fuel pump?
Old May 22, 2005 | 08:12 PM
Warrtalon's Avatar
Originally Posted by Widebandphillip
You don't need a fuel pump unless you're making more than 350 to the wheel. And arp headstuds aren't needed unless you build the engine.
Yeah, yeah, phillip, I see you say that all the time , but I think it's good to have with an S-AFC, especially if you crank the boost on race gas with extremely lean settings. Also, it costs less than $100 and is easy to install...
Old May 22, 2005 | 08:14 PM
Warrtalon's Avatar
Originally Posted by Sap12687
will i really feel the difference when i get my ECU back or is it very subtle?
You will definitely feel a difference. The car won't run pig rich at the top end, so it will pull harder to redline. Overall, you will gain significant HP across the entire power band...enough to feel it in the butt dyno.
