Do i need a fuel pump?
Old May 22, 2005 | 06:05 PM
Sap12687's Avatar
Question Do i need a fuel pump?
mods are below.
if so.....why? which one?
Old May 22, 2005 | 06:09 PM
smokedmustang's Avatar
I say No! not until you are adding MORE air, then you will need MORE fuel. Ie: intercooler, cams, are running higher boost, have an ecu flash. Not yet grasshopper
Old May 22, 2005 | 06:12 PM
housedj's Avatar
u only have 2 mods listed that actually GIVE you power. look at my '03 sig. i had to get a fuel pump cuz i run 25psi on 101 octane unleaded. once you flash & turn the boost up then you will need a fp.
Old May 22, 2005 | 06:16 PM
03BREvo8's Avatar
dont get a pump until you get cams , TBE, and a bigger FMIC
Old May 22, 2005 | 06:21 PM
Warrtalon's Avatar
Originally Posted by Sap12687
mods are below.
You need an exhaust and tuning first. You could have bought these things instead of the intake/bov and be hauling ***...
Old May 22, 2005 | 06:25 PM
housedj's Avatar
Wink
bloody well said!
Old May 22, 2005 | 06:27 PM
Sap12687's Avatar
tbe should be here in a few weeks...
Old May 22, 2005 | 06:28 PM
Warrtalon's Avatar
Ok, then get a flash designed for just those mods.
Old May 22, 2005 | 06:34 PM
Sap12687's Avatar
how exactly do the flashes work? i basically tell my ECU what im running and the car adjusts and uses them more efficiently?
Old May 22, 2005 | 06:55 PM
03BREvo8's Avatar
for those mods you just need the 199 flash .. a custom flash wont do anything if you dont have an exhaust..
Old May 22, 2005 | 07:09 PM
Warrtalon's Avatar
He said he will have it in a few weeks...
You send your ECU to Al@Dynoflash and have him program your ECU to run optimally for your mods: TBE, intake, BOV, MBC.
Old May 22, 2005 | 07:17 PM
4TUN8's Avatar
There are more vendors then just Al that do awsome tuning. I don't want to start the whole TurboTrix vs. Al arguement that's been beaten to death, but I'm partial to turbotrix tuning personally =p
Old May 22, 2005 | 07:39 PM
Warrtalon's Avatar
I would agree if you were making as much mph in the 1/4 as Peteyturbo with his flash+test pipe (only mods). But then again, he's an 05 (cheater), and I don't know whose flash he has, haha.
Yeah, TurboTrix is awesome, too. I was only giving an example above...
Old May 22, 2005 | 07:58 PM
Sap12687's Avatar
will i really feel the difference when i get my ECU back or is it very subtle?
Old May 22, 2005 | 08:11 PM
Widebandphillip's Avatar
You don't need a fuel pump unless you're making more than 350 to the wheel. And arp headstuds aren't needed unless you build the engine.
