Evo fuel pressure at fuel rail...
Old May 27, 2005 | 09:46 PM
Smogrunner's Avatar
What is our evo's system fuel pressure at the fuel rail? I'm trying to plug in all the values in this cool Injector size worksheet:
http://www.rceng.com/technical.htm#WORKSHEET
Old May 27, 2005 | 11:07 PM
JustDSM's Avatar
Base pressure is 43.5psi (no vac applied to the regulator). Actual idle pressure will vary depending on the ammount of vacuum your motor produces.
To figure your fuel pressure under boosted conditions add your boost pressure to the base fuel pressure. That is assuming your fuel system is operating propperly and you have a 1:1 increase in fuel pressure compared to boost.
Old May 28, 2005 | 11:39 AM
Karash's Avatar
So at 20 psi, the FPR should be at 63.5 psi?
Old May 28, 2005 | 11:58 AM
Z1 Performance's Avatar
yep
Old May 28, 2005 | 12:21 PM
Smogrunner's Avatar
Could someone with a fuel pressure gauge confirm this? At 20psi we should see around 63psi of fuel pressure, right. I have seen conflicting information on this. On Socalevo, it was said that the fuel pressure remains constant at about 43psi.
Old May 28, 2005 | 12:27 PM
then that's one messed up car
The car has a 1:1 RRFPR - it's base pressure at idle with the vacuum line connected is in the 33-36 ish range as I recall. With the vacuum line off its 43 ish. From there, it rises 1 psi for every psi of positive manifold pressure (boost) it sees. So at 20 psi, its 63, and 30 psi its 73, etc/ Now, throw a fuel pump into the mix without an adjustable fpr, and this can skew things somewhat, as your base pressure can rise - however on an Evo, it does not tend to go through the roof, so things stay pretty much consistent. This rise is due to the stock fpr not being able to bypass all the extra fuel its not seeing from the bigger flowing pump. So if your base pressure rises to, say, 46 psi, then at 20 psi, fpr should be 66 psi, and so on
Old May 28, 2005 | 12:55 PM
Smogrunner's Avatar
Thanks Adam, you rock.
Old May 28, 2005 | 01:09 PM
Ted B's Avatar
For that worksheet:
Crank HP is going to be close to what one expect to see recorded as whp on a Dynojet dyno + maybe 10% or less.
Brake Specific Fuel Consumption will be around 0.55
Most injectors are rated at 85-90% duty cycle, so 0.9 is a safe number.
System Fuel Pressure is 43psi + expected boost pressure (as Adam illustrated).
This will get you reasonable figures.
Old May 28, 2005 | 01:12 PM
Smogrunner's Avatar
Dang Ted, I owe you a beer too. I'm thinking 880's for my setup will be perfect. Now, which 880s?
Old May 28, 2005 | 01:41 PM
Ted B's Avatar
If you're running a GT35R, then 880s are fine.
Old May 28, 2005 | 01:53 PM
rlazer5000's Avatar
If your talking what brand, stick with AMS. U have their turbo kit so u know they have high quality products. Also, their fuel injectors are more affordable than most aftermarket companies.
Smogrunner's Avatar
Yes, AMS 2.3 with their 35R kit.
Old Jun 3, 2005 | 09:10 AM
crow's Avatar
My fuel reg was set at 43psi with the vac hose off at idle. when the vac hose is connected it reads anywhere from 32 - 36 psi. I want to know if this is an OK reading.
Old Jun 3, 2005 | 09:15 AM
perfect!
Old Jun 3, 2005 | 08:38 PM
Fourdoor's Avatar
The difference in pressure between the fuel and the air at the tip of the injector remains constant. With 20 psi of boost fuel pressure is raised to 63 psi.... but it is blowing fuel into an environment that is at 20 psi pressure over normal atmosperic pressure.... so the differential pressure remains constant.
The value you need to plug into the injector size program is the base pressure with no vacuum/boost signal.
Keith
